Lord Moreira
Banned till 9/16/03
- Jul 29, 2002
- U.S
I bought the smart case fan Thermaltake 80mm that i'm using to substitute the 7000rpm 60mm Thermaltake i had on my HS using a 60mm to 80 adapter.
the problem is the sensor isn't reading the temps right @ all!!
Even with a hair dryer blowing hot air i can't make it hit 5000rpm which it should automaticly hit under 35c.
Here are the specs...
2900rpm @ 25c
5000rpm @ 35c
46cfm @ 2900rpm
53cfm @ 5000rpm
My CPU and Case now are higher 39c and 39c under load and the fan just acts like it doesn't care
@ 3000\3100rpm
1- Can i extend the wire with regular wire (same gauge)so i can put it under the HS where it could get hotter to make it speed up?
2- Can i just cut the sensor off and tie the tips togheter to make it work @ 5000rpm @ all times?
3-Does anyone have this prob with this fan?
4-Can i buy 1 of those thermal sensors from ex:digidoc (just sensor) that are flat and can go under my cpu shim and make it work with this fan?
The highest i've been able to make it spin was 4000rpm and i was sqeezing the sensor
Or is this fan just defective....
Very dissapointed with it so far
The fan Can be looked @ Here
2900rpm @ 25c
5000rpm @ 35c
46cfm @ 2900rpm
53cfm @ 5000rpm
