I'm about to modify two MS6905 Master (Ver. 2.3) slotkets to marry a Tualatin each.
First will be a 1300/100MHz Celeron, 2nd a 1200/133/256K PIII. Both systems are IBM boards, where the BIOS does not allow any CPU settings (and MainBoardMonotor does not work).
I did much reading, also here, and ended up pretty confused.
Here are my questions:
1) I rather want to run the CPU at 1,5V for less power consumption. Any drawback? (I do not intent any overclocking.) So I just connect AM34 to AK36, right?
Further mods will be: connect AK4 to AK26 and insulate AN3, AK4 AJ3. That's it, right?
2) The MS 6905 comes with lots of jumpers. How do I set these?
J1/J4 (Overclocking Jumper): CPU define/100MHz/133MHz/Reserved ?
J3 (Single/Dual Processor Jumper): Celeron/Coppermine 256K ?
JV0-JV4 (Voltage Jumper): what effect do they have if I wire Vcore to 1,5V (by connecting AM34-AK36)???
Thanks in advance for any advice.
Mainz
Mainz
