Hallo
Someone might consider the tualatin mod on an Intel SE440BX-2 motherboard and I just want to tell you that it works.
I used an Asus S370-DL adaptor, removed 3 "pins" and wired ak4 to an11 (posted without wiring) and the 1,2ghz is stable in at least 124fsb (overclock with cpufsb). When I go for 133fsb it works only for a while but the cpu is not hot, I think it's because the 1/3 divider (44mhz pci). 1481mhz is not bad at all on a computer from 1998 with a MB from Intel.
