Tuniq Tower Question...
trendx
SoCal
Simply put.. can you mount the tuniq tower 2 different ways or 4 different ways because it will not fit in my case with the 680i the standard way which i see in reviews etc.
its hitting part of the motherboard or case ??
i know with the stacker 830 .. u have to take out the top 2 side fans and brackets
im curious cuz i just got a tuniq tower .. and plan on running a 680i board
You can turn it so it's "wide" or so it's "tall". Then you can position the fan on any of the four sides.
Well i have the lian-li v1000 and its hitting the bottom of the case because its an inverted chassis. Also the 680i processor placement is closer to the edge of the board. Now how i have it set up the air is pushing right down into the ground, there isnt much airflow in the tt as is but it cant be as good as it being a 180 degree turn.
No i would have to turn that sideways as well and mount the fan on top so it would be the same deal.
there are no holes in the side panel, i wish i could take a pic but my gf has my digital camera.
