TV out help
Puer Aeternus
In your head (Ottawa.Canada)
I have a 9700 pro built by ATI and have yet to get my TV out to work. The cables are all set up but no image coming out on the tv when I play w/ the display settings. Nvidia seemed so much easier to set up!
Thanks,
Puer
The Coolest
Senior Member
its actually VERY easy.
Go to display settings, Advanced, Displays and click the "Power" button on the picture with the TV. This should bring the picture to your TV, you can then adjust whatever you want to suit your TV better. Then you can even use your TV as an extended desktop, or just a mirror of your monitor
*EDIT:* Edited a typo.
Puer Aeternus
Puer Aeternus
Go to display settings, Adnaved, Displays and click the "Power" button on the picture with the TV. This should bring the picture to your TV, you can then adjust whatever you want to suit your TV better. Then you can even use your TV as an extended desktop, or just a mirror of your monitor
This is exactly what I did before posting and thought I musta had something wrong. TV out worked w/ my Nvidia card. Any other suggestions?
(Thanks the Coolest..glad you confirmed I was doing the right steps)
The Coolest
Senior Member
I know that I couldn't connect my old TV to the computer as I got a message that it can't find the TV, I never tried using the TV out on an nVidia card as I don't have one with a TV Out port, but with my new TV everything works great
