TV Tuner
FlakMonkey
Milwaukee
Okay, so I recently ordered my first card of this type...but have little to no idea how to get it running. I have a satellite box near the computer which is what I will be using, but I really don't know what kind of cables I will need to go to the card from the box.
Also, if I want to record a show like tivo, what does it record in? Will it bog down my PC when doing it? Thanks for whatever kind of help you guys can offer me!
Usually you'd use a 75 ohm coaxial cable, but S-VHS input will likely be available as well. I use Beyond TV to manage recordings & playback. It always records Mpeg 2 video which can then be transcoded to Mpeg 4 for greater compression if so desired. Recording video with my ATI Theater Pro 550 based tuner card using Beyond TV requires around 10% CPU time on this E6400 based system, and it was about the same on my s939 based system. It works perfectly in the background and I often don't even notice it's recording shows.
I'm curious, is there a guide somewhere on setting this up? I really have no idea where to start when I get this.
Where do the cords go from the back of this thing? One to the satellite box, then where? Something to my sound card & monitor?
Thanks for the info Timone, put my heart at ease about one aspect of this, don't have to worry about it eating up my CPU.
You haven't mentioned exactly which tuner card you're getting. The only guide you should require should come with your specific tuner device. I have experience with ATI based tuner cards, integrated tuner video cards (ATI AIW & Matrox), and also Hauppage tuners. I did have a Dish Network tuner connected to one of the AIW cards to record from at one time, and all I did was connnect the SVideo output from the Dish box to the SVideo input on the AIW card and the L & R Audio input to the soundcard. The AIW series has a line that you connect to the sound card to pick up the signal for recording. I currently just have an analog 75ohm cable line connected to a PCIx theater 550 card. It records both audio & video right from that input without any fanfare. The quality is as expected using coax...good...not great. This type of setup makes programs like Beyond TV shine, but with a seperate converter box, such as a digital cable or satellite converter things get a bit more complicated. You can either just run line in to the computer via Svideo & RCA audio and handle channel switching with the converter set top box or you can try to get the set top box to accept instruction from a computer program, which I believe is possible, but I've not attempted myself.
