- Feb 26, 2003
sweet guide
may want to add black vipers Xp tweaks to the list of sites
Mr.Guvernment said:sweet guide
may want to add black vipers Xp tweaks to the list of sites![]()
Gordon Airport said:Is there a realistic way to rank these setting in terms of performance gain from turning it off?
I know it would be difficult considdering how many card property variables ther are...It might also vary depending on the program you want the gain in.
Grande Juan said:That's wierd, I'm not even subscribed to this thread, I must have got your notification Malakai.
boostland said:Quote:
I also recommend running the NTFS file system for Windows XP, to change the file system of your drives requires a re-format; this can be done in Windows with exception to your main-drive. To format your main-drive to the NTFS file system simply boot off of the Windows XP CD-ROM and choose NTFS Format.
This can be done on any hard drive using the convert program.
CONVERT volume /FS:NTFS [/V] [/CvtArea:filename] [/NoSecurity] [/X]
volume Specifies the drive letter (followed by a colon),
mount point, or volume name.
/FS:NTFS Specifies that the volume is to be converted to NTFS.
/V Specifies that Convert should be run in verbose mode.
/CvtArea:filename
Specifies a contiguous file in the root directory to be
the place holder for NTFS system files.
/NoSecurity Specifies the converted files and directories security
settings to be accessible by everyone.
/X Forces the volume to dismount first if necessary.
All opened handles to the volume would then be invalid.
CONVERT C: /FS:NTFS
This would convert the C: drive from fat to Ntfs, It will require a reboot to compleat.
