Hi my name is Lukasz, and im new in forum so i want to say hi to everyone.
Ive found zalman raserator xt in my basement, and my friend had second zalman raserator v1 blue, so i did grab it as well for 5 euro.
Im planning to change hose size from zalmans weird size to more standard 3/8 i think it should be possible with xt, but how about v1 as it has kind of plastic screwed in fitting kind of connection?
In general my idea is to use v1 as a extra reservoir for zalman xt. i do want to change booth pumps however, xt will get liang ddc 10w and i want to install eheim in v1 with an extra hose inside to dump heated higher on. Ddc pump has flow about 420lt/h and the eihems are really cheap pumps (diffrence between 300 and 1000 lt/h are negligible. So will it hurt alot if i would order 1000lt version of eihem?
Loop will look like that
in --> raserator v1 --> raserator xt --> waterblocks
i have qute alot watts to dissipate ~500.
I know this setup is not perfect, but cost would be unbeatable ~70-90 euro for two pumps and some 3/8 hose?
Iff my thinking route is somehow wrong please correct me, as im not experienced watercooler. Any help would be apreciated
Regards
Regards
