- Jan 1, 2003
- Twain Harte, CA
My present rig uses a mix of Tygon R-3603 and Tygon 2275 tubing. The 2275 is more rigid than the R-3603, is harder to kink and makes a tighter radius. It has stayed "clearer" than the R-3603 (after about a year of use).
I'm about to build another radical water-cooled duallie, so am back in the "great tubing consumer mode".
But here's my thought... 2275 is considered "smooth bore high purity tubing" and works better than R-3603. Tygon S-50-HL is considered "ultra-smooth bore high purity tubing", so it may be even better than 2275.
Have any of you used S-50-HL? If so, what can you say about it?
