Ubuntu GPU-folding stuck with BAD_WORK_UNIT loop
gabi_golan
Hello, dear team members!
I'm recently trying to set up folding in ubuntu with my old 560ti gpu.
I've managed to setup V7 client, setup gpu slot (cpu folding is done via v6 client on the same machine).
The problem is: it downloads a WU, and when it is supposed to start working on it, it says BAD_WU, downloads a new one, and the loop goes on.
log:
Code:
20:35:35:  <capture-sockets v='false'/>
20:35:35:  <core-exec v='FahCore_$type'/>
20:35:35:  <core-wrapper-exec v='FAHCoreWrapper'/>
20:35:35:  <debug-sockets v='false'/>
20:35:35:  <exception-locations v='true'/>
20:35:35:  <gpu-assignment-servers>
20:35:35:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
20:35:35:  </gpu-assignment-servers>
20:35:35:  <stack-traces v='false'/>
20:35:35:
20:35:35:  <!-- Error Handling -->
20:35:35:  <max-slot-errors v='10'/>
20:35:35:  <max-unit-errors v='5'/>
20:35:35:
20:35:35:  <!-- Folding Core -->
20:35:35:  <checkpoint v='10'/>
20:35:35:  <core-dir v='cores'/>
20:35:35:  <core-priority v='low'/>
20:35:35:  <cpu-affinity v='false'/>
20:35:35:  <cpu-usage v='100'/>
20:35:35:  <gpu-usage v='100'/>
20:35:35:  <no-assembly v='false'/>
20:35:35:
20:35:35:  <!-- Folding Slot Configuration -->
20:35:35:  <cause v='ANY'/>
20:35:35:  <client-subtype v='LINUX'/>
20:35:35:  <client-type v='normal'/>
20:35:35:  <cpu-species v='X86_PENTIUM_II'/>
20:35:35:  <cpu-type v='AMD64'/>
20:35:35:  <cpus v='-1'/>
20:35:35:  <gpu v='true'/>
20:35:35:  <max-packet-size v='normal'/>
20:35:35:  <os-species v='UNKNOWN'/>
20:35:35:  <os-type v='LINUX'/>
20:35:35:  <project-key v='0'/>
20:35:35:  <smp v='true'/>
20:35:35:
20:35:35:  <!-- GUI -->
20:35:35:  <gui-enabled v='true'/>
20:35:35:
20:35:35:  <!-- HTTP Server -->
20:35:35:  <allow v='127.0.0.1'/>
20:35:35:  <connection-timeout v='60'/>
20:35:35:  <deny v='0/0'/>
20:35:35:  <http-addresses v='0:7396'/>
20:35:35:  <https-addresses v=''/>
20:35:35:  <max-connect-time v='900'/>
20:35:35:  <max-connections v='800'/>
20:35:35:  <max-request-length v='52428800'/>
20:35:35:  <min-connect-time v='300'/>
20:35:35:  <threads v='8'/>
20:35:35:
20:35:35:  <!-- Logging -->
20:35:35:  <log v='log.txt'/>
20:35:35:  <log-color v='true'/>
20:35:35:  <log-crlf v='false'/>
20:35:35:  <log-date v='false'/>
20:35:35:  <log-date-periodically v='21600'/>
20:35:35:  <log-debug v='true'/>
20:35:35:  <log-domain v='false'/>
20:35:35:  <log-header v='true'/>
20:35:35:  <log-level v='true'/>
20:35:35:  <log-no-info-header v='true'/>
20:35:35:  <log-redirect v='false'/>
20:35:35:  <log-rotate v='true'/>
20:35:35:  <log-rotate-dir v='logs'/>
20:35:35:  <log-rotate-max v='16'/>
20:35:35:  <log-short-level v='false'/>
20:35:35:  <log-simple-domains v='true'/>
20:35:35:  <log-thread-id v='false'/>
20:35:35:  <log-thread-prefix v='true'/>
20:35:35:  <log-time v='true'/>
20:35:35:  <log-to-screen v='true'/>
20:35:35:  <log-truncate v='false'/>
20:35:35:  <verbosity v='5'/>
20:35:35:
20:35:35:  <!-- Network -->
20:35:35:  <proxy v=':8080'/>
20:35:35:  <proxy-enable v='false'/>
20:35:35:  <proxy-pass v=''/>
20:35:35:  <proxy-user v=''/>
20:35:35:
20:35:35:  <!-- Process Control -->
20:35:35:  <child v='false'/>
20:35:35:  <daemon v='false'/>
20:35:35:  <fork v='false'/>
20:35:35:  <pid v='false'/>
20:35:35:  <pid-file v='Folding@home Client.pid'/>
20:35:35:  <respawn v='false'/>
20:35:35:  <service v='false'/>
20:35:35:
20:35:35:  <!-- Remote Command Server -->
20:35:35:  <command-address v='0.0.0.0'/>
20:35:35:  <command-allow-no-pass v='127.0.0.1'/>
20:35:35:  <command-deny-no-pass v='0/0'/>
20:35:35:  <command-enable v='true'/>
20:35:35:  <command-port v='36330'/>
20:35:35:
20:35:35:  <!-- Slot Control -->
20:35:35:  <idle v='false'/>
20:35:35:  <max-shutdown-wait v='60'/>
20:35:35:  <pause-on-battery v='false'/>
20:35:35:  <pause-on-start v='false'/>
20:35:35:  <paused v='false'/>
20:35:35:  <power v='medium'/>
20:35:35:
20:35:35:  <!-- User Information -->
20:35:35:  <machine-id v='0'/>
20:35:35:  <passkey v=''/>
20:35:35:  <team v='0'/>
20:35:35:  <user v='gabi'/>
20:35:35:
20:35:35:  <!-- Web Server -->
20:35:35:  <web-allow v='127.0.0.1'/>
20:35:35:  <web-deny v='0/0'/>
20:35:35:  <web-enable v='true'/>
20:35:35:
20:35:35:  <!-- Web Server Sessions -->
20:35:35:  <session-cookie v='sid'/>
20:35:35:  <session-lifetime v='86400'/>
20:35:35:  <session-timeout v='3600'/>
20:35:35:
20:35:35:  <!-- Work Unit Control -->
20:35:35:  <dump-after-deadline v='true'/>
20:35:35:  <max-queue v='16'/>
20:35:35:  <max-units v='0'/>
20:35:35:  <next-unit-percentage v='99'/>
20:35:35:  <stall-detection-enabled v='false'/>
20:35:35:  <stall-percent v='5'/>
20:35:35:  <stall-timeout v='1800'/>
20:35:35:
20:35:35:  <!-- Folding Slots -->
20:35:35:  <slot id='1' type='GPU'>
20:35:35:    <client-type v='advanced'/>
20:35:35:  </slot>
20:35:35:</config>
20:35:35:Trying to access database...
20:35:35:Successfully acquired database lock
20:35:35:Enabled folding slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti]
20:35:35:Started thread 5 on PID 4302
20:35:35:Started thread 6 on PID 4302
20:35:35:Started thread 7 on PID 4302
20:35:35:Started thread 8 on PID 4302
20:35:35:Started thread 9 on PID 4302
20:35:35:Started thread 10 on PID 4302
20:35:36:WU00:FS01:Connecting to 171.67.108.200:80
20:35:38:WU00:FS01:Assigned to work server 140.163.4.233
20:35:38:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti] from 140.163.4.233
20:35:38:WU00:FS01:Connecting to 140.163.4.233:8080
20:35:39:WU00:FS01:Downloading 4.27MiB
20:35:40:Started thread 11 on PID 4302
20:35:44:WU00:FS01:Download complete
20:35:44:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10467 run:0 clone:114 gen:88 core:0x17 unit:0x0000008e538b3db9538bbcc69e391f21
20:35:44:WU00:FS01:Starting
20:35:44:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/student/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 4302 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
20:35:44:WU00:FS01:Started FahCore on PID 4320
20:35:44:Started thread 12 on PID 4302
20:35:44:WU00:FS01:Core PID:4324
20:35:44:WU00:FS01:FahCore 0x17 started
20:35:44:WU00:FS01:0x17:*********************** Log Started 2014-12-23T20:35:44Z ***********************
20:35:44:WU00:FS01:0x17:Project: 10467 (Run 0, Clone 114, Gen 88)
20:35:44:WU00:FS01:0x17:Unit: 0x0000008e538b3db9538bbcc69e391f21
20:35:44:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:35:44:WU00:FS01:0x17:Machine: 1
20:35:44:WU00:FS01:0x17:Reading tar file state.xml
20:35:45:WU00:FS01:0x17:Reading tar file system.xml
20:35:45:WU00:FS01:0x17:Reading tar file integrator.xml
20:35:45:WU00:FS01:0x17:Reading tar file core.xml
20:35:45:WU00:FS01:0x17:Digital signatures verified
20:35:45:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
20:35:45:WU00:FS01:0x17:Saving result file logfile_01.txt
20:35:45:WU00:FS01:0x17:Saving result file log.txt
20:35:45:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:35:45:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:35:45:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:10467 run:0 clone:114 gen:88 core:0x17 unit:0x0000008e538b3db9538bbcc69e391f21
20:35:45:WU00:FS01:Uploading 1.84KiB to 140.163.4.233
20:35:45:WU00:FS01:Connecting to 140.163.4.233:8080
20:35:46:WU00:FS01:Upload complete
20:35:46:WU01:FS01:Connecting to 171.67.108.200:80
20:35:46:WU00:FS01:Server responded WORK_ACK (400)
20:35:46:WU00:FS01:Cleaning up
20:35:48:WU01:FS01:Assigned to work server 140.163.4.231
20:35:48:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti] from 140.163.4.231
20:35:48:WU01:FS01:Connecting to 140.163.4.231:8080
20:35:49:WU01:FS01:Downloading 4.84MiB
20:35:55:WU01:FS01:Download 83.94%
20:35:55:WU01:FS01:Download complete
20:35:55:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:298 clone:2 gen:122 core:0x17 unit:0x000000d4538b3db75328a43330712f1b
20:35:55:WU01:FS01:Starting
20:35:55:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/student/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 4302 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
20:35:55:WU01:FS01:Started FahCore on PID 4328
20:35:55:Started thread 13 on PID 4302
20:35:55:WU01:FS01:Core PID:4332
20:35:55:WU01:FS01:FahCore 0x17 started
20:35:56:WU01:FS01:0x17:*********************** Log Started 2014-12-23T20:35:55Z ***********************
20:35:56:WU01:FS01:0x17:Project: 13001 (Run 298, Clone 2, Gen 122)
20:35:56:WU01:FS01:0x17:Unit: 0x000000d4538b3db75328a43330712f1b
20:35:56:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:35:56:WU01:FS01:0x17:Machine: 1
20:35:56:WU01:FS01:0x17:Reading tar file state.xml
20:35:56:WU01:FS01:0x17:Reading tar file system.xml
20:35:56:WU01:FS01:0x17:Reading tar file integrator.xml
20:35:56:WU01:FS01:0x17:Reading tar file core.xml
20:35:56:WU01:FS01:0x17:Digital signatures verified
20:35:56:WU01:FS01:0x17:ERROR:exception: Bad platformId size.
20:35:56:WU01:FS01:0x17:Saving result file logfile_01.txt
20:35:56:WU01:FS01:0x17:Saving result file log.txt
20:35:56:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:35:56:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:35:56:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13001 run:298 clone:2 gen:122 core:0x17 unit:0x000000d4538b3db75328a43330712f1b
20:35:56:WU01:FS01:Uploading 1.84KiB to 140.163.4.231
20:35:56:WU01:FS01:Connecting to 140.163.4.231:8080
20:35:58:WU01:FS01:Upload complete
20:35:58:WU00:FS01:Connecting to 171.67.108.200:80
20:35:58:WU01:FS01:Server responded WORK_ACK (400)
20:35:58:WU01:FS01:Cleaning up
20:35:59:WU00:FS01:Assigned to work server 140.163.4.233
20:35:59:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti] from 140.163.4.233
20:35:59:WU00:FS01:Connecting to 140.163.4.233:8080
20:36:00:WU00:FS01:Downloading 4.32MiB
20:36:05:WU00:FS01:Download complete
20:36:05:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10468 run:0 clone:101 gen:76 core:0x17 unit:0x00000088538b3db95388d1c72552b990
20:36:05:WU00:FS01:Starting
20:36:05:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/student/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 4302 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
20:36:05:WU00:FS01:Started FahCore on PID 4335
20:36:05:Started thread 14 on PID 4302
20:36:05:WU00:FS01:Core PID:4339
20:36:05:WU00:FS01:FahCore 0x17 started
20:36:06:WU00:FS01:0x17:*********************** Log Started 2014-12-23T20:36:05Z ***********************
20:36:06:WU00:FS01:0x17:Project: 10468 (Run 0, Clone 101, Gen 76)
20:36:06:WU00:FS01:0x17:Unit: 0x00000088538b3db95388d1c72552b990
20:36:06:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:36:06:WU00:FS01:0x17:Machine: 1
20:36:06:WU00:FS01:0x17:Reading tar file state.xml
20:36:06:WU00:FS01:0x17:Reading tar file system.xml
20:36:06:WU00:FS01:0x17:Reading tar file integrator.xml
20:36:06:WU00:FS01:0x17:Reading tar file core.xml
20:36:06:WU00:FS01:0x17:Digital signatures verified
20:36:06:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
20:36:06:WU00:FS01:0x17:Saving result file logfile_01.txt
20:36:06:WU00:FS01:0x17:Saving result file log.txt
20:36:06:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:36:07:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:36:07:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:10468 run:0 clone:101 gen:76 core:0x17 unit:0x00000088538b3db95388d1c72552b990
20:36:07:WU00:FS01:Uploading 1.84KiB to 140.163.4.233
20:36:07:WU00:FS01:Connecting to 140.163.4.233:8080
20:36:07:WU01:FS01:Connecting to 171.67.108.200:80
20:36:07:WU00:FS01:Upload complete
20:36:08:WU00:FS01:Server responded WORK_ACK (400)
20:36:08:WU00:FS01:Cleaning up
20:36:09:WU01:FS01:Assigned to work server 171.67.108.52
20:36:09:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti] from 171.67.108.52
20:36:09:WU01:FS01:Connecting to 171.67.108.52:8080
20:36:10:WU01:FS01:Downloading 1.52MiB
20:36:16:WU01:FS01:Download 36.90%
20:36:18:WU01:FS01:Download complete
20:36:18:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:532 clone:3 gen:89 core:0x17 unit:0x000000776652edc45399eaf5952b4c84
20:36:18:WU01:FS01:Starting
20:36:18:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/student/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 4302 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
20:36:18:WU01:FS01:Started FahCore on PID 4343
20:36:18:Started thread 15 on PID 4302
20:36:18:WU01:FS01:Core PID:4347
20:36:18:WU01:FS01:FahCore 0x17 started
20:36:19:WU01:FS01:0x17:*********************** Log Started 2014-12-23T20:36:18Z ***********************
20:36:19:WU01:FS01:0x17:Project: 9201 (Run 532, Clone 3, Gen 89)
20:36:19:WU01:FS01:0x17:Unit: 0x000000776652edc45399eaf5952b4c84
20:36:19:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:36:19:WU01:FS01:0x17:Machine: 1
20:36:19:WU01:FS01:0x17:Reading tar file state.xml
20:36:19:WU01:FS01:0x17:Reading tar file system.xml
20:36:19:WU01:FS01:0x17:Reading tar file integrator.xml
20:36:19:WU01:FS01:0x17:Reading tar file core.xml
20:36:19:WU01:FS01:0x17:Digital signatures verified
20:36:19:WU01:FS01:0x17:ERROR:exception: Bad platformId size.
20:36:19:WU01:FS01:0x17:Saving result file logfile_01.txt
20:36:19:WU01:FS01:0x17:Saving result file log.txt
20:36:19:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:36:19:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:36:19:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9201 run:532 clone:3 gen:89 core:0x17 unit:0x000000776652edc45399eaf5952b4c84
20:36:19:WU01:FS01:Uploading 1.83KiB to 171.67.108.52
20:36:19:WU01:FS01:Connecting to 171.67.108.52:8080
20:36:20:WU00:FS01:Connecting to 171.67.108.200:80
20:36:20:WU01:FS01:Upload complete
20:36:21:WU01:FS01:Server responded WORK_ACK (400)
20:36:21:WU01:FS01:Cleaning up
20:36:22:WU00:FS01:Assigned to work server 140.163.4.231
20:36:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti] from 140.163.4.231
20:36:22:WU00:FS01:Connecting to 140.163.4.231:8080
20:36:22:WU00:FS01:Downloading 4.83MiB
20:36:28:WU00:FS01:Download 77.57%
20:36:28:WU00:FS01:Download complete
20:36:28:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13000 run:342 clone:3 gen:46 core:0x17 unit:0x0000004c538b3db7530ffc728c15a3b1
20:36:28:WU00:FS01:Starting
20:36:28:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/student/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 4302 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
20:36:28:WU00:FS01:Started FahCore on PID 4352
20:36:28:Started thread 16 on PID 4302
20:36:28:WU00:FS01:Core PID:4356
20:36:28:WU00:FS01:FahCore 0x17 started
20:36:29:WU00:FS01:0x17:*********************** Log Started 2014-12-23T20:36:28Z ***********************
20:36:29:WU00:FS01:0x17:Project: 13000 (Run 342, Clone 3, Gen 46)
20:36:29:WU00:FS01:0x17:Unit: 0x0000004c538b3db7530ffc728c15a3b1
20:36:29:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:36:29:WU00:FS01:0x17:Machine: 1
20:36:29:WU00:FS01:0x17:Reading tar file state.xml
20:36:29:WU00:FS01:0x17:Reading tar file system.xml
20:36:29:WU00:FS01:0x17:Reading tar file integrator.xml
20:36:29:WU00:FS01:0x17:Reading tar file core.xml
20:36:29:WU00:FS01:0x17:Digital signatures verified
20:36:29:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
20:36:29:WU00:FS01:0x17:Saving result file logfile_01.txt
20:36:29:WU00:FS01:0x17:Saving result file log.txt
20:36:29:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:36:30:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:36:30:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13000 run:342 clone:3 gen:46 core:0x17 unit:0x0000004c538b3db7530ffc728c15a3b1
20:36:30:WU00:FS01:Uploading 1.84KiB to 140.163.4.231
20:36:30:WU00:FS01:Connecting to 140.163.4.231:8080
20:36:30:WU01:FS01:Connecting to 171.67.108.200:80
20:36:30:WU00:FS01:Upload complete
20:36:30:WU00:FS01:Server responded WORK_ACK (400)
20:36:30:WU00:FS01:Cleaning up
20:36:31:WU01:FS01:Assigned to work server 140.163.4.233
20:36:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti] from 140.163.4.233
20:36:31:WU01:FS01:Connecting to 140.163.4.233:8080
20:36:31:WU01:FS01:Downloading 4.92MiB
20:36:37:WU01:FS01:Download 45.72%
20:36:40:WU01:FS01:Download complete
20:36:40:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10469 run:0 clone:39 gen:77 core:0x17 unit:0x00000097538b3db95388d314ae255bb4
20:36:40:WU01:FS01:Starting
20:36:40:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/student/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 4302 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
20:36:40:WU01:FS01:Started FahCore on PID 4361
20:36:40:Started thread 17 on PID 4302
20:36:40:WU01:FS01:Core PID:4365
20:36:40:WU01:FS01:FahCore 0x17 started
20:36:41:WU01:FS01:0x17:*********************** Log Started 2014-12-23T20:36:40Z ***********************
20:36:41:WU01:FS01:0x17:Project: 10469 (Run 0, Clone 39, Gen 77)
20:36:41:WU01:FS01:0x17:Unit: 0x00000097538b3db95388d314ae255bb4
20:36:41:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:36:41:WU01:FS01:0x17:Machine: 1
20:36:41:WU01:FS01:0x17:Reading tar file state.xml
20:36:41:WU01:FS01:0x17:Reading tar file system.xml
20:36:41:WU01:FS01:0x17:Reading tar file integrator.xml
20:36:41:WU01:FS01:0x17:Reading tar file core.xml
20:36:41:WU01:FS01:0x17:Digital signatures verified
20:36:41:WU01:FS01:0x17:ERROR:exception: Bad platformId size.
20:36:41:WU01:FS01:0x17:Saving result file logfile_01.txt
20:36:41:WU01:FS01:0x17:Saving result file log.txt
20:36:41:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:36:42:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:36:42:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:10469 run:0 clone:39 gen:77 core:0x17 unit:0x00000097538b3db95388d314ae255bb4
20:36:42:WU01:FS01:Uploading 1.84KiB to 140.163.4.233
20:36:42:WU01:FS01:Connecting to 140.163.4.233:8080
20:36:42:WU00:FS01:Connecting to 171.67.108.200:80
20:36:42:WU01:FS01:Upload complete
20:36:43:WU01:FS01:Server responded WORK_ACK (400)
20:36:43:WU01:FS01:Cleaning up
20:36:44:WU00:FS01:Assigned to work server 140.163.4.233
20:36:44:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti] from 140.163.4.233
20:36:44:WU00:FS01:Connecting to 140.163.4.233:8080
20:36:44:WU00:FS01:Downloading 4.27MiB
20:36:50:WU00:FS01:Download 77.59%
20:36:50:WU00:FS01:Download complete
20:36:50:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10467 run:0 clone:161 gen:88 core:0x17 unit:0x000000a0538b3db9538bbde5017c25b0
20:36:50:WU00:FS01:Starting
20:36:50:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/student/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 4302 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
20:36:50:WU00:FS01:Started FahCore on PID 4369
20:36:50:Started thread 18 on PID 4302
20:36:50:WU00:FS01:Core PID:4373
20:36:50:WU00:FS01:FahCore 0x17 started
20:36:51:WU00:FS01:0x17:*********************** Log Started 2014-12-23T20:36:50Z ***********************
20:36:51:WU00:FS01:0x17:Project: 10467 (Run 0, Clone 161, Gen 88)
20:36:51:WU00:FS01:0x17:Unit: 0x000000a0538b3db9538bbde5017c25b0
20:36:51:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
20:36:51:WU00:FS01:0x17:Machine: 1
20:36:51:WU00:FS01:0x17:Reading tar file state.xml
20:36:51:WU00:FS01:0x17:Reading tar file system.xml
20:36:51:WU00:FS01:0x17:Reading tar file integrator.xml
20:36:51:WU00:FS01:0x17:Reading tar file core.xml
20:36:51:WU00:FS01:0x17:Digital signatures verified
20:36:51:WU00:FS01:0x17:ERROR:exception: Bad platformId size.
20:36:51:WU00:FS01:0x17:Saving result file logfile_01.txt
20:36:51:WU00:FS01:0x17:Saving result file log.txt
20:36:51:WU00:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
20:36:51:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:36:51:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:10467 run:0 clone:161 gen:88 core:0x17 unit:0x000000a0538b3db9538bbde5017c25b0
20:36:51:WU00:FS01:Uploading 1.85KiB to 140.163.4.233
20:36:51:WU00:FS01:Connecting to 140.163.4.233:8080
20:36:52:WU01:FS01:Connecting to 171.67.108.200:80
20:36:52:WU00:FS01:Upload complete
20:36:52:WU00:FS01:Server responded WORK_ACK (400)
20:36:52:WU00:FS01:Cleaning up
20:36:53:WU01:FS01:Assigned to work server 140.163.4.231
20:36:53:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 560 Ti] from 140.163.4.231
20:36:53:WU01:FS01:Connecting to 140.163.4.231:8080
20:36:54:WU01:FS01:Downloading 4.83MiB
20:36:55:FS01:Paused
20:36:59:WU01:FS01:Download complete
20:36:59:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13001 run:55 clone:7 gen:52 core:0x17 unit:0x0000007a538b3db753285f7469fd9f20
20:37:37:Saving configuration to config.xml
I've tried adding and removing the ADVANCED flag for GPU slot - same result.
OS is Ubuntu 12.04 with all the updates, kernel ver: 3.13.0-43-generic, Nvidia proprietary drivers installed, ver. 331.113 - recomended by Ubuntu.
Also, it's worth to mention, that this GPU ran folding for 1.5-2 years in the past, had some thermal stress (70-78C), and had NAN problems afterwards (Not a Number - calculation errors). However, it runs games fine, including in Linux.
So what can be done?
Also, i've noticed that it says 'CUDA - not detected', but other forum says, that CUDA is only relevant for Windows.
https://foldingforum.org/viewtopic.php?f=80&t=26417
Code:
22:35:11:   Platform: linux2 3.2.0-1-amd64
22:35:11:       Bits: 64
22:35:11:       Mode: Release
22:35:11:******************************* System ********************************
22:35:11:        CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
22:35:11:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
22:35:11:       CPUs: 8
22:35:11:     Memory: 7.72GiB
22:35:11:Free Memory: 6.90GiB
22:35:11:    Threads: POSIX_THREADS
22:35:11: OS Version: 3.13
22:35:11:Has Battery: false
22:35:11: On Battery: false
22:35:11: UTC Offset: 2
22:35:11:        PID: 2243
22:35:11:        CWD: /home/student
22:35:11:         OS: Linux 3.13.0-43-generic x86_64
22:35:11:    OS Arch: AMD64
22:35:11:       GPUs: 1
22:35:11:      GPU 0: NVIDIA:2 GF114 [GeForce GTX 560 Ti]
[COLOR="#00FF00"]22:35:11:       CUDA: Not detected[/COLOR]
22:35:11:***********************************************************************
22:35:11:<config>
That is probably caused by degraded GPU, rather than software problem: I've tried running it in Windows, with win drivers: it still gives the Bad WU errors.
Although it seems to run games fine, including a short test in Linux, it's probably a card degraded/damaged by folding, some of it under high temps (like 78C), and thats the reason for failing WU's.
that's what it's looking like to me, a bad gpu.
but please let this thread simmer a while, someone might have an idea or two.
Have you tried turning the fan speed up to maximum? Perhaps its just over heating at too low a fan speed.
orion456, yes. The card currently has an aftermarket cooler plugged directly into molex, the temps at folding load are about 55C or lower, so it's not overheated now.
Robert17, im actually done trying making it fold, its probably a damaged/degraded GPU.
I've had similar issues with an MSI branded 560 Ti. I could not get the card to work in two machine but it worked great in a third machine. All three machines were Windows based. Worked in 8.1 but not in Vista or SBS 2008. All 64 bit.
