- Dec 9, 2003
- Orlando, FL
Any good action/adventure or RPGs (not MMO)
Funny how there's a lot of great free and open software for Linux until it comes to games... why is this?
I can see Fudge's point though. It's a lot faster and easier for software developers to program applications and games on closed hardware (Macs and consoles) and the code can be highly optimized for it.
Google ... release an OS
So you take like, for example, Firefox source code and compile it for your exact processor?
That's pretty interesting.
$ cat /var/db/pkg/www-client/mozilla-firefox-3.0.3/CFLAGS
-march=amdfam10 -pipe -fPIC -Wno-return-type -w
$ cat /var/db/pkg/www-client/mozilla-firefox-3.0.1/CFLAGS
-march=athlon-xp -pipe -Wno-return-type -w
$ equery uses mplayer
[ Searching for packages matching mplayer... ]
[ Colour Code : set unset ]
[ Legend : Left column (U) - USE flags from make.conf ]
[ : Right column (I) - USE flags packages was installed with ]
[ Found these USE variables for media-video/mplayer-1.0_rc2_p27725-r1 ]
U I
+ + 3dnow : Adds support for 3dnow multimedia processor instructions
+ + 3dnowext : Enable 3dnowext cpu instructions
+ + X : Adds support for X11
+ + a52 : Enables support for decoding ATSC A/52 streams used in DVD
+ + aac : Enables support for MPEG-4 AAC Audio
+ + aalib : Adds support for media-libs/aalib (ASCII-Graphics Library)
+ + alsa : Adds support for media-libs/alsa-lib (Advanced Linux Sound Architecture)
- - altivec : Adds support for optimizations for G4 and G5/ppc970 processors
- - amrnb : Enables Adaptive Multi-Rate Audio support (Narrow Band)
- - amrwb : Enables Adaptive Multi-Rate Audio support (Wide Band)
- - arts : Adds support for aRts: the KDE sound daemon
+ + bidi : Enables bidirectional language support
- - bindist : Flag to enable or disable options for prebuilt (GRP) packages (eg. due to licensing issues)
- - bl : Enables Blinkenlights support in mplayer
+ + cddb : Access cddb servers to retrieve and submit information about compact disks
- - cdio : Use libcdio for CD support (instead of cdparanoia)
+ + cdparanoia : Enables cdparanoia (audio CD ripper) support
- - cpudetection : Enables runtime cpudetection (useful for bindist, compatability on other CPUs)
- - custom-cflags : Enables custom CFLAGS (UNSUPPORTED)
- - custom-cpuopts : Fine-tune custom CPU optimizations (UNSUPPORTED)
- - debug : Enable extra debug codepaths, like asserts and extra output. If you want to get meaningful backtraces see http://www.gentoo.org/proj/en/qa/backtraces.xml
- - dga : Adds DGA (Direct Graphic Access) support for X
- - dirac : Enable Dirac video support (an advanced royalty-free video compression format) via the reference library: dirac.
- - directfb : Adds support for DirectFB layer (library for FB devices)
+ + doc : Adds extra documentation (API, Javadoc, etc)
+ + dts : Enables DTS Coherent Acoustics decoder support
+ + dv : Enables support for a codec used by many camcorders
+ + dvb : Adds support for DVB (Digital Video Broadcasting)
+ + dvd : Adds support for DVDs
- - dxr3 : Enable DXR3/H+ video output
- - enca : Enables support for charset discovery and conversion
+ + encode : Adds support for encoding of audio or video files
+ + esd : Adds support for media-sound/esound (Enlightened Sound Daemon)
- - fbcon : Adds framebuffer support for the console, via the kernel
+ + ftp : Adds FTP (File Transfer Protocol) support
- - ggi : Adds support for media-libs/libggi (non-X video api/drivers)
+ + gif : Adds GIF image support
+ + gtk : Adds support for x11-libs/gtk+ (The GIMP Toolkit)
+ + iconv : Enable support for the iconv character set conversion library
+ + ipv6 : Adds support for IP version 6
- - jack : Adds support for the JACK Audio Connection Kit
+ + joystick : Add support for joysticks in all packages
+ + jpeg : Adds JPEG image support
+ + kernel_linux : <unknown>
- - ladspa : Enables the ability to support ladspa plugins
+ + libcaca : Add support for colored ASCII-art graphics
+ + lirc : Adds support for lirc (Linux's Infra-Red Remote Control)
+ + live : Enables live.com streaming media support
+ + lzo : Enables support for lzo compression
+ + mad : Adds support for mad (high-quality mp3 decoder library and cli frontend)
- - md5sum : Enables md5sum video output
+ + mmx : Adds support for optimizations for Pentium MMX and Athlon class processors
+ + mmxext : Enables mmx2 support
+ + mp2 : Enables support for twolame, an MP2 audio library
+ + mp3 : Add support for reading mp3 files
+ + musepack : Enable support for the musepack audio codec
+ + nas : Adds support for network audio sound
- - nemesi : Enable Nemesi Streaming Media support
+ + openal : Adds support for the Open Audio Library
+ + opengl : Adds support for OpenGL (3D graphics)
+ + oss : Adds support for OSS (Open Sound System)
+ + png : Adds support for libpng (PNG images)
+ + pnm : Add PNM video output option, to create PPM/PGM/PGMYUV images
- - pulseaudio : Adds support for PulseAudio sound server
- - pvr : Enable Video4Linux2 MPEG PVR
+ + quicktime : Adds support for OpenQuickTime
- - radio : Enable V4L2 radio interface and support
- - rar : Enable Unique RAR File Library
+ + real : Adds real video support
- - rtc : Enables usage of the linux real time clock. The alternative is software emulation of rtc
+ + samba : Adds support for SAMBA (Windows File and Printer sharing)
- - schroedinger : Enable Dirac video support (an advanced royalty-free video compression format) via libschroedinger (high-speed implementation in C of the Dirac codec).
+ + sdl : Adds support for Simple Direct Layer (media library)
- - speex : Adds support for the speex audio codec (used for speech)
+ + srt : Internal SRT/SSA/*** (SubRip / SubStation Alpha) subtitle support
+ + sse : fast floating point optimization for PentiumIII+ class chips
+ + sse2 : faster floating point optimization for SSE2 capable chips
- - ssse3 : faster floating point optimization for SSSE3 capable chips (Intel Core 2 and later chips)
- - svga : Adds support for SVGAlib (graphics library)
- - teletext : Support for TV teletext interface
- - tga : Enables Targa video output
+ + theora : Adds support for the Theora Video Compression Codec
+ + truetype : Adds support for FreeType and/or FreeType2 fonts
+ + unicode : Adds support for Unicode
+ + v4l : Enables video4linux support
- - v4l2 : Enable video4linux2 support
- - video_cards_mga : <unknown>
- - video_cards_s3virge : <unknown>
- - video_cards_tdfx : <unknown>
- - video_cards_vesa : <unknown>
- - vidix : Support for vidix video output
+ + vorbis : Adds support for the OggVorbis audio codec
- - win32codecs : use win32codecs package for dll avi decoding support (wmv and what not)
+ + x264 : Enable h264 encoding using x264
+ + xanim : Enables support for xanim based codecs
- - xinerama : Add support for the xinerama X11 extension, which allows you to stretch your display across multiple monitors
- + xscreensaver : Adds support for XScreenSaver extension
+ + xv : Adds in optional support for the Xvideo extension (an X API for video playback)
+ + xvid : Adds support for xvid.org's open-source mpeg-4 codec
+ + xvmc : Enables X-Video Motion Compensation support
+ + zoran : Enables ZR360[56]7/ZR36060 video output
cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Pentium(R) Dual CPU E2200 @ 2.20GHz
stepping : 13
cpu MHz : 3299.974
cache size : 1024 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe lm constant_tsc arch_perfmon pebs bts pni monitor ds_cpl est tm2 ssse3 cx16 xtpr lahf_lm
bogomips : 6599.94
clflush size : 64
power management:
processor : 1
cpu family : 6
model : 15
stepping : 13
cpu MHz : 3299.974
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 10
wp : yes
bogomips : 6599.88
clflush size : 64
power management:
$ sudo nano -w /etc/X11/xorg.conf
(change driver to "nv")
$ sudo /etc/init.d/gdm restart
(open terminal app)
$ sudo apt-get install linux-restricted-modules
(change driver back to "nvidia")
(then log out or hit ctrl-alt-backspace to restart xorg)
