udma or pio for raid?
J
JEFF
Guest
finally got my second drive,setup raid but not sure of a couple of settings.set drives to udma 5 because i wasn't sure of the correct setting.which is faster or compatible with my drives?pio4 or dma or udma5 or somthing else.setting up raid i lost all my bookmarked sites and cant find pauls unofficial to research this.if u can help with either i would be appreciative...oh i chose 32 bit size in raid(was guessing)is that correct?
If your HDD's are ata/100, then set them for udma5. That means they are 100's, 66's are udma4. UDMA is much better then PIO1-4. CDROM's run on PIO's for older versions. The newer ones can go to the DMA or UDMA's. Hope this helps ya out.
PIO4 is quite fast, actually. It just consumes huge amounts of CPU time, so it's a no no. UDMA is the way.
thanx guys i did finnaly get a bios page to research and yall r right on!
i'm still not sure of block size but sandra says i should use smaller,i'm waisting disc space.
If possible, try experimenting with the block size.
4096bytes is quite optimal for the current processors, as they store data in 4k pages.
