- Mar 6, 2002
- Monroe, Georgia
Well, this is disappointment. I was going to install my Z4 kit thinking everything should connect together. Well, I was wrong. Look closely at the picture. You will notice the left side is slightly larger than the right.
The dang hose supplied in the kit will fit over the right side, but not the left side.
I was thinking of buying some more hose and sliding one hose in the other to make up the difference.
Need some advice, what would you do to make it work?
Regards,
Joe
Regards,
Joe
