ULTIMATE Gaming Computer
Im also afraid that if i watercool, i wont know how to put it together cause many people say it is difficult. Plus and cant find a w/c kit for that cpu.
Watercooling realy isnt necessary. I had it, and it wasnt that great. Its quieter per cooling power than air, but for me it wasnt worth the maintenance. Grab yourself an Slk-948 or XP-120 heatsink.
the fx series of processors fit under athlon 64's in watercooling so any block made for Athlon 64 fits the FX. i do suggest watercooling because i have a Athlon 64 and it produces a lot of heat. if you go with water it will help but with air i had to keep my fans on hi and even in that i was getting a lot of heat from the CPU. I recommend watercooling as an Athlon 64 owner bt you can do what you want.
get the steelpad s&s or xray-pad thunder 9 mx510 and pc-155's from sennheiser (what the pro gamers use) or a supermat thier 17x11,like the above post go 3000 fx53,I no gamers(clanmates) with both and thier awsome,get an ideazon zboard or the logitech elite keyboard. Oh ya,get a mouseclip also just to be cool
That mousepad you want is crap. Get an icemat. I've heard from some friends back east that a lot of people at big LANs there use them. I'll be getting the 11x14" (I think that's teh size) pad eventually. It's a glass mousepad, and it's only $50. VERY precise BTW.
Don't get that mousepad, get a Steelpad S&S. Also I would suggest dropping the MX510 and going for an MX1000. No matter how much wire supporters complain about lag, it won't lag if you use it correctly.
