SOLVED ultra ata66 drivers for be6-ll r2
M
madmax
Guest
i can't find the drivers for this new motherboard , were they included on the cdrom or was they on a seperate 3.5 disk , the manual for this motherboard seem like they come on a disk but i didnt receive one with this board only 3.5 disk i have is labeled Hotrod 100 pro which i dont think are the drivers. can anyone tell me where i can find them . your advice will be appreciated. are anyone running the drivers on there board.
I believe Hotrod is the name for the HTP chip. I think the latest rev of this board has a raid controller but it's probably still called the "Hotrod". Check on their site (Abit). Try installing them through windows plug-n-play, if they are not the correct drivers windows will say so. After installation they should show up as a scsi device in system manager.
I too have a be6II rev2 and that floppy has the drivers you need and also you should have gotten a cdrom and temp probe. if you didn't get those 2 items i would wonder if you bought a returned mobo. just a thought.
Thank you alot guys i found the drivers i needed it was on the 3.5 disk .running right now on this board @980. this board is awesome after you get it configured right .
