- Apr 8, 2002
- San Jose, CA
iam planing to build a good performance system ( closed to 2.0ghz after O/C probly with 1600+ AGOIA) but running low on budget so I'm considering a refurb mobo. I have checked those few top selection mobos from newegg:
REFURBISHED: ABIT KX7-333 Socket A VIA KT333 Motherboard $45
REFURBISHED: ASUS A7V8X 1000Mb/s LAN, Firewire IEEE1394, Serial ATA DDR400 AMD Athlon/Athlon XP/Duron Socket A, Processor Mother Board $79
REFURBISHED: Epox Motherboard for AMD Socket A Processors, model EP- 8K5A2+ $79
Which mobo do you recommend ??? Is it worth to try refurb mobo , especially from newegg ( any troublesome from using refurb mobo ? )
thx
Umm maybe A7V8X would be a good choice since later I can upgrade to faster CPU w/o changing the mobo
thx
