Hello everyone!
I'm new in this forum, and new in the world of overclocking. I built my own computer a few years ago with these features:
Motherboard: Asus P6X58D-E
CPU: Intel Core i7 950 @ 3,07GHz
RAM: Corsair Dominator CMP8GX3M4A1600C8 x 4
GPU: XFX Radeon HD 6870
OS: Win 7 Professional 64bit
During this summer I wanted to look into overclocking to increase the performance of my computer. I have done a lot of googling to learn and understand the basics of overclocking, where one of the guides i read came from this forum: http://www.overclockers.com/3-step-guide-overclock-core-i3-i5-i7/
I followed this guide step by step. I lowered the CPU and RAM multipliers to the lowest setting, the unclock multiplier to RAM x 2, and adjusted the voltage of the IOH to 1,3 and QPI/VTT to default 1,2V. I was actually able to increase the base clock to 218 MHz without even increasing the QPI/VTT volt a single increment. But when i reach 219 MHz, the computer wont even start! :S
When I boot with a base clock of 219 MHz the screen stays black for about 20 secs. Then the computer gives a beep, but this beep is longer than the usual beep you get when booting. Then the ordinary boot screen appears (American Megatrends) but it is really slow and freezes when reaching "Detecting USB Devices". Then I am forced to reboot manually. When booting for the second time, the boot screen works as normal, but when I am supposed to enter Windows, the computer gives another beep, and a message appears:
"Overclocking failed! Please enter Setup to re-configure your system."
By my knowledge, this can not be caused by too low QPI/VTT Voltage, as this should have caused a bluescreen earlier on. I have used Prime95 and RealTemp for stressing the CPU and monitoring the temperature, and it all works out fine after 5 minutes of stress testing.
Does anyone have any idea why my computer is unable to boot when reaching 219 MHz base clock? Thank you for any help!
(Sorry if my explanation is bad. I may explain it in greater detail if you request me to.)
