SOLVED Undo accident with gparted?
ihrsetrdr
Señor Senior Member
Close to the San Andreas Fault
I was in a rush and accidentally deleted a partition(and clicked "apply") in gparted, that housed my backed-up files on a PATA drive. :bang head
In gparted under Edit, the "undo last operation" feature is grayed out, is there any hope for recovery?
I'm off to jury duty for the day; I really hope that this stupid disaster can be undone.
:cry:
Edward78
Seems like there would be, I think it only deleted the info saying the location of the data & the data is still there.
Stratus_ss
Overclockix Snake Charming Senior, Alt OS Content
Ontario Canada
if you havent formatted or done anything reconstructing teh partition walls will usually restore your data. I have done this before without consequence but as always YMMV!
also if you can try testdisk.
Stratus_ss
Ontario Canada
Hey now what am i chopped liver?
I suggested it first I just didnt put the fancy how-to link :p
