The relavent components of my build are:
-MSI 7950 twin frozr
-pentium e5800
-8 gigs of 1333mhz ram
-750 watt thermaltake 80+ bronze power supply
Let me start by stating that the card does get very good airflow and that I have enough power going to it.
The problems I have so far is that the core clock gets stuck at either 500 mhz or 300 mhz and the memory clock gets stuck at 1250 mhz or 150 mhz. Catalyst Control Center also won't load anymore so I'm limited to afterburner, I'm including this problem because it is the direct result of my efforts to fix this absolutely terrible card.
The things I've done to fix it are as follows:
-Reinstalled the drivers. No Dice, and broke Catalyst.
-Installed the drivers from the disk included. Still no changes.
-Removed my second monitor (see side notes for more info)
-Attempted to turn hardware acceleration off (see side notes for more info)
-Swapped power cables just in case. No changes.
Side Notes:
I've read in a few places that this issue was usually the result of people playing games on one monitor and watching a video on another. This was not the case for me, as I don't watch videos and play games at the same time. They had also stated turning off hardware acceleration in the display settings had fixed it, so I attempted this just in case that was the issue. I found that the AMD drivers did not let me change this, and I also found that when I attempted to do it with the drivers removed, the changes could not be saved in the registry. I removed my second monitor, as this was the only link between my case and everyone elses' experience.
I'm not pleased at all with my purchase of the 7950, and will not be purchasing any more AMD related products ever again. My last video card was a 6850 and burned itself out in less than a year. However, I would like to get this problem fixed so I can continue on with my life.
If it helps anyone narrow down the issue, I'm using a 24" HDMI monitor paired with a 19" VGA monitor (using a DVI to VGA adapter). The latest drivers I had installed was 12.10. Also, when I first installed the card and got the drivers, AMD's auto detect thing didn't see my card, and whenever I install the drivers manually it says that it had several warnings. I'm not sure if this is normal but it also says 0x1002 - 0x679A pci in place of the actual model of my card.
Any help would be much appreciated.
|UPDATE|
After several doses of percocet and a rage nap, I tried the 12.11 drivers and CCC seems to have fixed itself, so that's one problem down. At the moment I have disabled any and all video enhancing options to my knowledge in CCC, in an effort to make something happen. Still nothing. Also, the driver auto detect kind of worked after I installed the drivers from the disc. Only catch is it thought I had vista. So that's where the situation is at now. Any help would still be very much appreciated.
-pentium e5800
Side Notes:
|UPDATE|
