Yup, that is correct, chief.Gnufsh said:The last chip the pencil trick worked on was the t-birds. Pallys were locked, but you had to use somethingto fill the pits, and something more conductive than most pencils (there were, actually, a few pencils that would work, but normal ones didn't).
Pikachu_Mommy said:Looks like Packrat doesn't even know what he is saying.. HA HA
ThoroughbredXP 1800 chip is UNLOCKED. It's not FACTORY LOCKED. It's UNLOCKED. You didnt' even say what mobo you got either. No info on anything.. Via KT266a mobo should be able to adjust multipliers upto 12.5x with that chip. Via KT333 mobos should be able to adjust them upto 12.5x multiplier. Some KT400 should be able to adjust the multi at even wider range. Nforce2 boards should be able to adjust all most multipliers with that chip.
That is if the chip was released before AMD started hard/permanent locking the chips recently. Yup, The Coolest and Maxima88 are saying correct. Listen to them and answer their ques...
HA HA HA HA HAHAHAHAHAHA
