Unlocking 2000+, is it the same as unlocking a 1800+ or 1900+???
G
Geron
Delawhere?
All i need to know is. dose the 2000+ XP unlock buy just connecting the level1 bridges? Like the 1600/1700/1800/1900's do. I know the 2100 requries alot more work. BUT DOSE THE 2000 UNLOCK EASY LIKE THE 1800????
jbslow
Arizona
What do you mean the 2100+ requires alot more work? I unlocked then sold my first 1600+ it didnt seem to difficult. If the 2000+ and 2100+ are truely XP's then they should unlock the same way right.
G
Geron
Delawhere?
I thought i read on these fourms that the 2100+, was hard to unlock. somthing about a Dremmel and cutting. I just wanted to know.
jbslow
Arizona
You are right the 2100+ is hard to unlock. I dont think you'll have the same troubles with your 2000+ though because the default multiplier is still 12.5 but a newer one may be altered its hard to say.
Check this article out I'm a little skeptical of the 12.5 and below , 13 and above L10 rule because I had the 1600+ I unlocked running at 13x and 14x. It was weird though cause when I selected a 5x133 multiplier I would get 14x47 and the 12.5x133 would give me 13x128.
yogi99
I have a 2000+ and I can assure you the lazer trenches are quite a bit smaller than any other xp's I've seen.
Mine is running at 12.5 x 150 fsb, but above that the pci is running at 40....I think my nic card isn't liking it too much.
I wouldn't doubt the 2000+ and 2100+ have been changed a little.
Anyone on these forums successfully unlock a 2000+ AGOIA???:
