- Aug 1, 2010
- CORSAIR CMPSU-400CX 400W
This is my first post on this board as I've tried everything and now am desperate. I have checked the entire forums on information regarding how to do this properly and it has not been of any help. Any help will be appreciated, thanks in advance!
Computer Specs:
Motherboard - GIGABYTE GA-MA785GM-US2H
Power Supply - CORSAIR CMPSU-400CX 400W
Hard Drive - Western Digital Caviar Blue WD5000AAKS 500GB
Video Card - 2600XT ATI Radeon
Case - Antec 900 I
Processor - AMD Athlon X2 5000+ (2.2Ghz Stock)
Heatsink - Cooler Master Hyper 212+
Memory - 4 x 1GB Corsair DDR2 800 (5-5-5-18)
I recently just purchased the AMD Athlon X2 5000+, hearing that it unlocks very well with the motherboard I had purchased. I unlocked the cores through bios, but everytime I boot up Windows 7, there are some artifacts on the screen. Surfing on the internet, doing daily applications are very glitchy also. Although browsing is very glitchy on the computer along with some artifacts, there has never been a crash whatsoever.
Here are the steps I took in trying to make things work:
- Installed Windows 7 Professional x64 on the Hard Drive
- Restarted, launched BIOS, went to (MIT).
- Changed Hyrbid on "EC Firmware Selection" and "Auto" on "ACC"
- Computer restarted, and then I started to have artifacts
- I restarted once again and went into bios, Changed Manual under ACC
- Default settings were -2% for each core, I upped cores 2/3 in increments
- It still had artifacts by the time cores 2/3 were up to +12%,
- I even decreased cores 0/1 by -4%
I obviously have no clue what I am doing, so I asked one of my cousins for help who has overclocked many things before. He recommended that I upped the voltage of the CPU to help stablize my CPU cores. I went into BIOS and upped the Vcore in lowest increments. Still didn't work. I then thought that maybe one of the cores that I had unlocked were bad. I disabled Core 2 in Bios, same problem. I then enabled Core 2, and disabled Core 3, still bad. I then disabled Cores 2/3 and still bad. I tried upping my memory voltage (VDIMM) , to stock 1.8 to 1.9.
I flashed the motherboard's bios from F7 to F11, also didn't help. If I get get quad core, I would really love tri-core, or maybe both cores are defective.
Currently CPU-NB Voltage is at 1.35V, and CPU Voltage is at 1.45V. I'm not sure if this indicates anything, but right when I turn on my computer and launch internet explorer, Windows 7 changes from Aero theme to Basic theme. There are no more artifacts on the desktop, scrolling through the thread is still glitchy, and pictures are filled with artifacts. I have the latest drivers for my video card, 10.7 Catalyst.
Originally I was using the 4200HD integrated graphics card that the motherboard had provided. I thought that it was the graphics card because it I only saw artifacts when in pictures/scrolling. Also when I maximized my screens, it would be slow to open completely, similar to the effects if you don't have the graphics driver installed. I installed the driver for the 4200HD and it had the same issue. I then pulled my 2600XT from my other system and installed it. This video card is a POS and was giving me issues in my other rig, for it to run properly, I had to underclock it. Its now in this current system that I'm trying to overclock. I have the latest drivers, which I got from Guru3d. Also, I just installed RivaTuner, and underclocked the video card, now I am seeing artifacts on my desktop once again.
Thank you in advance, I hope this is enough to clarify!
Computer Specs:
Case - Antec 900 I
