Unlocking an Athlon XP 1600 retail.
darrin
TX
Is it worth the hassle?
I'll admit that the thought of superglueing and putting conductive paint on my retail chip doesn't exactly give me a warm fuzzy feeling.
:rolleyes:
Cluster
Canuckistan
If the thought of applying sticky glue to holes smaller than the size of a pin tip, then globbing a bunch of of condictive liquid in a line as thin as the hair on you head, then you might not wanna attempt it. I fried my XP1700 because i had 2 adjacent bridges shorting out.
On the other hand, if you got ba**s of steel, and don't get sweaty palms at the thought of losing 100 bucks, then i hope all turns out well.
Ugmore Baggage
I strongly recomend using a multimeter to test for shorts before plugging it back in... then again my XP isn't unlocked (I only got it today)
Arkaine23
Captain Random Senior Evil
xp1600+ unlocked
Unlocked, locked, partially unlocked, unlocked, locked, unlocked. Guess I'm a little paranoid cuz whenever I have a stability problem I lock my cpu again, for fear the defogger paint has shifted or crumbled. I can unlock it on the first try now, and even paint a bridge or two freehand.
Crayon + defogger method.
