Unlocking my 1200MHZ DURON
Bergfuerst
VIENNA/.at
I Have now a 1200MHZ duroN! But i cant unlocking it!
Normaly this Processor have 4L1 Britches but my one have 5!?
Whats up there!
Cause I have a Overclocking Friend from Austria and he has this CPU too!
BUt he has only 4 L1 Britches in one litte!
cjlax5
San Diego
its because u have the new morgan core. unlocking should be the same as before, connect all the bridges. someone correct me if im wrong
B
Bergfuerst
VIENNA/.at
No its not right I`ve tried it!
Morgen core ok - But he has the SAME CPU!
1200MHZ DURON IS MAYBE NOT THE SAME LIKE 1200MHZ DURON
Milkman
NH Biodiesel master
I also asked about the 5 L1's on my 2000+ and the reply was that the extra bridge was for multipliers beyond 12, as thesen are not supported just connect the first 4 going from the L1 and you should be good to go;)
cjlax5
San Diego
they make the 1200 MHZ duron with the Morgan core and with out. your friend probably has an older one and u have a newer one with the new core. if i am missing something tell me
Yodums
Senior Member
Ottawa, Canada
The Morgans have 5 L1 bridges. You might wanna try to erase the marks off, then clean the surface with isopropyl, let it dry abit (1min), then try reconnecting it, with a cleaner unlock. It might be just that your not unlocking it clean enough. I used a mechanical pencil for some precision, then I used a 10x magnifying glass to see if it was good.
What I did was:
I lightly traced over the bridges, then I darkened them like hell for like 5mins so they wouldn't go away!
Then I inspected with a magnifying glass.
Yodums
