If you have a kt400 board, the mulitpliers are already unlocked. But if you don't, I don't believe it is the same, but someone else should answer that.
Like what nothing said, if you are using a mobo based on the kt400 chipset, you can use all the multipliers, since the Tbred came unlocked. If you are using a mobo based on the kt333 chipset, then you need to connect the 5th L3 bridge to get access to all the lower multipliers under 13x.
