- May 6, 2001
- Cheshire UK
I have Motherboard Monitor 5.06 monitoring my system and cpu temps, and I have calculated the compensation values by matching the Windows readings (when idle) with the BIOS readings.
My idle cpu temp at the moment is 49, and my system temp is 42. These are the exact same temperatures that the BIOS reports, and these are typical idle temps for my system. Ambient room temp is 24. I thought perhaps that these might be fairly normal readings, until I did a search of these forums and found that most peoples idle cpu temps are 25-35 and only reach the 40's when doing intense 3D gaming. Mu cpu goes into the 50's during intense gaming, but never goes over 60, and rarely over 55.
BTW, SiSoft Sandra 2001SE reports 38 for system temp, and 37.5 for cpu temp.
Any suggestions on what may be wrong? Maybe my BIOS readings are wrong?
My system: 133Mhz FSB 1Ghz PIII, Abit SA6R mb (latest BIOS), 256MB unbranded P133Mhz RAM, running Windows 2000 Pro SP2.
Cooling: ThermoEngine V60-4210 on CPU, CardCooler XT on cards/mb, 80mm Coolermaster on the front, 92mm CoolerMaster extracting at the rear.
