UPDATE ON K7S5A no boot problem
AUDU MOHAMMED
CHICAGO
1)
K7S5A MB
AMD Duran 900
128MB SDRAM
10GB HD
TNT2 N64-VIDEO
2)
K7S5A MB2
AMD DURAN 1.0MHZ
256MB SDRAM
20GB HD
ATI PCI XPERT
My problem is the power is working,the CD-R seem to be ok,but the monitor is blank and no beep.
I tried so many things i could think of all to no avail.
NO BEEP AT ALL.....HELP.
UPDATE
I am stuck with two K7S5A because i cannot figure out what the problem really is . Tried so many things all to no avail, so i gave up.
Now, i need to get a replacement for my CPU AMD DURAN 1.0 and 900MHZ.
Please will anyone help me out here, which motherboard to get and reasonablly price to replace my K7S5A.
THANKS.
MikeBD35
Albany, New York
For a bunch of VB formatting tips click on the blue f.a.q. button above. Go to "Are there any special codes/tags I can use to format my posts and messages?" and click on the "click here" hyperlink. It explains how to do all the cool stuff, maybe I'll read it sometime :) .
Mike
Dragonbud
Orange County, California
today, i got a 1.3 duron and an ecs k7s5a.
I've got the same problems as you. NO POST, blank screen.
There is power though.
Even changed psu's, change/reseated vid cards, changed/re-seated/moved around ram, even switched chips. CPU is good.
returning mobo tomorrow. Cleared cmos, changed battery, and still a NO GO. returning mobo first thing in the morning..
:mad: :mad: :eh?:
Kendan
Senior Punk
Dark side of hell
:mad: :mad: :eh?:
Trty and reseat the vid card. When I first set mine up I had the same problem. it turned out to be the vid card was not seated all the way in even though I thought it was.
JetMech
s
Ditto. I've had this problem on several boards. Two ECS, one P4T, and one KR7A. All were corrected by reseating the vid card. A call to a local computer store helped me. The main clue is the "no beep". I don't know why Mobo manuals don't share this. It could save them a lot of RMAs. If you get the same prob on two boards, like the situation in this thread, nine times out of ten it's not the board. Peace.:beer:
A
AUDU MOHAMMED
CHICAGO
I took the board to be tested and it will cost me $35-45 in my neck of town.Besides, i'll rather get a new board than pay that much to have it tested.
Anyway, last night i took everything out of the board except the CPU and there was no beep. Is there any else that i can do at this point. :confused: :burn: :mad:
Thanks MIKE.
Dragonbud
yes, i did try reseating the vid card, even switched vid cards.
Pushed it all the way down and hard enough to worry about stressing the vid card and damaging it.
still no luck, even tried a pci card. what gives....
maxima88
mobos are very sensitive to static electricity.
I just replaced my hsf and next thing I know, no beeps or posts.
The store I bought it from tested it, sd it was shot and replaced it. Good thing it was still under warranty.
