- Nov 28, 2015
hi all
i have decided to low budget customize a 2009 business desktop that my old boss gave me a few years back. this will be my initial foray into building/customizing computers, so i have limited knowledge and experience. i don't want to replace mobo yet because right now that is out of my comfort zone. after some research, i think i want to put a Phenom x4 960t in it. the current board supports am2+/am3 cpus at 95w max. i will get latest bios when i am ready to install. i am curious about overclocking (i do understand not all boards will allow unlocking add'l cores). after the cpu is installed and i reboot, will i get a screen with options to customize clock settings and try to unlock cores?
next, i understand core voltage and temperatures are important. with stock cpu fan, is 1.45 core voltage and around 50C adequate? this will be a 24hr computer. i read that cpu multipliers can be around 17-19 (3.8ghz) safely and nb multiplier at 13 (2.4ghz). i am not sure what any of this means. the integrated graphics were replaced years ago with an Asus 8400gs. i will putting in a sapphire hd7750 soon and utilize the hdmi port. it is compatible with the current board and doesn't require separate power supply.
as it stands, the computer runs really well and is very stable even when i have Word Perfect, Word, Adobe Pro and numerous google tabs open. i can play star wars old republic with no problems.
i want to know if after i upgrade the cpu and install the 7750, will i be considerably faster than i am now and will i be able to play most games (even if not on highest settings? i have seen videos of an hd7750 playing witcher 3 at 32fps and rainbow seige at 42fps. these are pretty decent numbers for a card that is almost 4yrs old and doesnt use a separate power supply.
this is my first attempt at customizing and this is more for experimental purposes than for practical purposes.
Compaq 505b microtower
Nvidia nforce 430 chipset
3gb ddr3 ram, 1600
Asus 8400gs
3gb ddr3 ram, 1600
Asus 8400gs
