Ok, in 2018 I built my PC with a de-lidded 8700k and 2080ti with the following items:
I am now looking to update my components, I have a Lian Li PC-O11 Dynamic Tempered Glass ATX Mid-Tower.
Leaning toward an AMD 9800x3d combo from MC, eventually updating to a RTX 4080 or 5080 possibly.
A couple things I want to change:
- Watercool WCP D5-VARIO 12V Pump with a 200mm reservoir.
- Bitspower G1/4" Matte black fittings.
- Bitspower None Chamfer PETG 16mm OD Rigid Tubing
- 2x XSPC TX360 Ultrathin Radiators (top case and front back behind res).
- Move from rigid to flex for serviceability ease.
- Does anyone know if the existing Bitspower G1/4" fitting will work with flexible tube or do I need barbed fittings?
- My pump and reservoir will need relocated to fit a RTX 4080 or 5080 as there is not enough room as currently mounted.
- Pretty sure I will need to ditch this current reservoir setup due to space.
- Do I really need a reservoir? Easier to fill a loop with one I imagine.
- Not planning to water block whatever GPU I end up with, I realize this 9800x3d doesn't really need 2x 360mm rads but I have them so might as well use them.
