- Apr 30, 2009
- Wentzville, MO
Hey guys,
I went from a i7 920 to a Xeon X5650 running on a Asus P6X58.
Considering the CPU is lower wattage I can't see it over taxing anything. As the world burns (the smell is really bad) the PC works fine. It's so odd as I expected it to either not start, or at least crash. The smell starts to form in only about 30 seconds. I also notice a weird sound once it gets to windows, almost like a HD crunching away. However I only have SSD's and do not have a DVD drive. My video card has made a whining noise before, so maybe I can hear this odd noise now that my CPU fan is nearly silent (doubt it).
The only component that feels hot is the Northbridge heat sink. I can't really touch it after 30-45 seconds. It's held down with a spring and can easily move. BUT I figure if the sink on it is burning hot it's pulling heat from the NB.
Ok, so can bad CPU's make any sort of noise? Could the northbridge be burning alive? I don't see any swelling capacitors and although usually the PSU's are guilty I don't smell anything from its insides once it's fans are shut down.
UPDATE: I did some more digging, perhaps it's not the northbridge thats getting hot, but the VRM bank. And I believe I miss guessed the component. It seems the SB and NB are sharing the same heatpipe running between them. And this is a row of black rectangles next to the CPU. So... if I am on the right path why all of a sudden are these melting, and why have they not failed already?
Thanks for the help!
