Replaced a core 2 duo e5400 with a q6600, on a machine that doesn't see very much usage at load. I'm not too confident with replacing cpu's so I took it to a friends' place, the dual was running at 55c idle before I packed it up (hot day). I noticed that my friend replaced the stock fan with one that seemed to be turning really slowly, he said that's normal and it will speed up when under load. The cpu at his place reached 50c as soon as we turned it on.
Anyway, I got home and noticed that the idling speed for the cpu fan is only 800rpm... it's IDLING at 65c. I just did a prime95 test and the fan speed went up to 4000 rpm, but not before the cpu hit 85c (!!!) - now it's idling at 69. I suspect the fan, but could it be because I'm using a stock dual core fan on a quad? I've never even heard the stock fan spin up when running the dual core at load.
