- Oct 18, 2011
Hey guys,
I'm planning on upgrading my case in the next few months (I have grown tired of both the noise and appearance of my HAF 932, even though it is a perfectly functional case). The two contenders at the moment are the Phanteks Evolv ATX and the Cooler Master Master Case 5. I'm currently leaning towards the Evolv for purely aesthetic reasons, since the two appear to have similar functionality. However, I am concerned about airflow and dust, given I am currently running SLI 970s on air only. As you can see in my signature, I'm running closed loop on my CPU, so I'm not concerned about the cooling on that. I live in Canada, and my computer is in the basement, so the ambient temperature is usually solid between 18-22 degrees Celsius depending on the time of year.
If I buy the Evolv, I'm planning on moving the two 140s preinstalled on the front to the top for exhaust and adding 3 Noctua 120s to the front for intake. However, I'm not entirely certain this will be enough to offset the heat generated by SLI 970s. As you can see, the case has plenty of space and there will be no HDD mounts in the way to block airflow.
The Master Case 5 appears to have plenty of air cooling right out of the gate, so I'm not concerned about its cooling capabilities should I go that route.
I was wondering if any of you guys have had any experience with running an air-cooled build in the Evolv, or any experience running in a similar specc'd case on air? Any input here would be greatly appreciated.
P.S. I'm not really concerned about cost, and I will be selling my HAF 932 once the upgrade is complete.
