- Feb 20, 2002
Hey all
I have my T-bird 1.2(AYHJAR 01 something) at 1495mhz(13x115) at 1.8v.The default(for the chip) is 1.75 but my motherboard sucks a$$ and has a fixed voltage of 1.8.
The thing that bothers me is that when i connect all the L7 bridges,i do get a voltage of 1.9-1.91(i read somewhere that ASUS boards tend to give more than the needed voltage thus 1.9 instead of 1.85)) but the chip wont go any higher.To be honest it worked once at 1560(13x120) but i lowered the speed because of insufficient cooling...50 idle.
My motherboard goes up to 120mhz(any higher and it wont boot...) and its very stable.Most of the time i had the cpu running at 12x120 and i had no problems at all.
Do you think the chip just wont go any higher?
I cant believe that a whole 0.1volts dont make any difference
PS:with cpufsb i can run the mb at 133fsb stable so i dont think thats the problem.
Edit:Temps at 1495 are 35-36 idle 40-41 full load
