upscaling dvd question
jimmsch
NY
Does my ATI GPU upscale a DVD I am playing in the DVD drive to 1080p. The res is currently set at 1080p and the TV can render 1080p, but does that mean that any DVD I might play in the DVD drive will be upscaled automatically?
HTPC specs in sig.
Thanks -Jim
Wicked Klown
Hard *** Southern Boy Senior
Sheboygan, Wisconsin
Yea it will play the dvd at the res you have your video card set to. Just remember it will not get rid of black bars, when doing it. Some movies may look grainy as well.
ratbuddy
HTPC specs in sig.
Thanks -Jim
It will be upscaled to fit the display but not necessarily upconverted properly. That depends what player and codec you are using. Some look much better than others, although the default ones in a modern player program usually do an OK job.
