SOLVED Urgent Help needed on Vista Sharing.
Amnesiac
Pakistan.
I am seriously c.blocked now!. I want to copy stuff off from my D drive and whatever i do, i cant share it. Well technically it is shared but it cant be accessed. Tried sharing individual folders, but the same damned error.
Both 32bit Vistas. Fully updated.
My: Ultimate.
Copying to: Home Premium (Laptop).
Tried plugging the network cable but someone said that you cant do that unless you have a crossover cable. Then again i have a 4 port router and even that doesn't work. Same 'not accessible' error.
Help!.
Try using this method:
start > run > \\PC name with documents that you want copy\d$
The system will ask for authentication, so, write this:
Username: pcname(the same that you wrote in 1st step)\user with admin rights
Password: user password
Let me know if that works
Ok. Finally a video that helped me. I still cant share the whole drive, but now i can access the individual folders. Had to change the Workgroup of both computers to something else.
