I got 3 new USB 3.1 Vantec HDD case's in today and I live in Canada and I'm having a friend of mine in the State's ship me the ASRock USB 3.1 Front Panel,I don't know why but no one in Canada right is carrying the ASRock Front Panel,good old Newegg.com has the Front Panel but not Newegg.ca so that means I couldn't order it myself as I don't in the States.
So anyway I get the HDD case's and from what I can see they are a USB A Type plug and if I didn't know any better they are just a USB 3.0 plug on both ends one being A Type and the other Micro B.
Is it the partly the cable that makes USB 3.1 faster or is it just the controller,I really don't care I just don't want to find out that the cable is going to be a big bottle neck,if I get 300Mb transfer speed's I'd even be happy with that I as I transfer a lot of data at time's.I'm hoping to see a bit of a speed increase with an HDD I plan to try as well.
Are there any good programs that can let you monitor the transfer speeds to see what's really going on.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811990012
http://www.newegg.ca/Product/Produc...7&cm_re=vantec_usb_3.1-_-17-392-087-_-Product
