Same... yeah... no clue, dude. It's all over the map... from what do I use a USB-C connector to, TB, to charging phones...Edit: Or not. Whatever.
ICANT
...glad we helped...I guess!
Isn't that an "Apple" standard? I think it provides power and data to both charge your device and display graphics and network traffic and.... on and on. It also uses a USB-C style connector but has a slightly different pin-out. I also think that they are (at least generally) compatible with each other.Ok explain to me what is thunderbolt and what devices use it?
So.........again.......... Thunderbolt is a faster protocol than USB3.2 (not USB4). TB4 runs up to 40 Gbps using a Type-C connector (see my link that covers the different types of USB connections). USB 3.2 Gen2x2 runs up to 20 Gbps, but the new USB4 runs up to 40 Gbps as well. Like Don mentioned, in order to get the most out of the connection, both ends need to be Type-C or you're limited to Type-A speeds.Ok explain to me what is thunderbolt and what devices use it?
The "Lightning" connector is an apple thing (and NOT Type-C). Thunderbolt is not... the rest of what you said is spot on.Isn't that an "Apple" standard?
WHAT connector? We've talked about several already... you need to be specific!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!I guess I just don't understand that connector I bought an ASUS Z790-H MB and it has lots of different colored usb ports one of them has to be a fast connection.
Thank you. I like how you displayed the MB.Exactly (RTFM!).... or look at the specs page for that board on its website. All the info is there.
ROG STRIX Z790-H GAMING WIFI | Motherboards | ROG United States
The ROG Strix Z790-H is the perfect complement to Intel 13th Gen processors with its 16-stage power solution and intuitive AI Overclocking utility.rog.asus.com
From your mobo's website..........
You have TWO Type-C ports on the rear IO (20 Gbps and 10 Gbps), and one 20 Gbps connector for front panel Type-C. You DO NOT have Thundebolt natively on this machine. You'd need to buy an expensive card and attach it to the Thunderbolt HEADER (#17 from the image in your manual below).
EDIT: Also from your manual...
