- May 4, 2011
So; the exact featureset I am looking for is
1 USB Type C Connector(to the port on the PC itself) (longish cable so I don't block my exhaust vent; I'm going to use velcro or double-sided tape to secure to the rear of my Air 540.)
4 USB 3.1 Type A (on the hub)
1 SD Card Reader (On the hub)
Passes power AND Data through
Ideally, it would match the silver aluminum that my case is; But that's less of a priority.
I busted out my front IO of my Air 540 awhile back of the front USB 3.0 cables(tripped on a wire conneted to the front panel), so I wanted to get some more inputs back to connect my endless cacophony of random devices again
I have been doing research, and the closest one I found is This one by IOGEAR. My Caveats are No SD Card reader or longish wire on the hub itself(as its designed with laptops in mind)
Here is one that advertises Mac first stuff: HooToo Type C
Any ideas?
Any ideas?
