Walaka7:
I have made a small discovery on the A7M-266D rev 1.03 boards and bios 1010 (I have not tried any other bios yet).
This may be a general limitation with AMD based Dual motherboards but i'm not sure.
After modding both cpu's to get the 24X multiplier to be available. I have noticed a major increase in PCI latency going from anything over a 14X multiplier.
For example. When benchmarking my 160 Gig WDJB hard drives using HDTach 2.7, with any multiplier set higher then 14X, my Hard drive average speed drops from 48 MegaBytes to roughly 20 Megabytes. Also, as a more simple test, run a ping -t in a cmd window to your default gateway ip address before and after setting a 14X mutiplier with Crystal CPUID, you will notice a small but noticeable increase of around 3-4 ms when it should always be less then 1ms.
The only reason I started testing these things out was because I noticed a general sluggishness that is usually not apparent with dual cpu systems.
I'm guessing the reason for the increase in pci latency is due to the higher multipliers or maybe due to the fact that these boards are only physically equipped with a 4bit multiplier and not a 5bit like newer Nvidia/Via based boards.
I'll dig a little more but for now my old *real* MP1900's are going back in to see if this latency exists with those chips if I can figure out how to unlock them.
Perhaps you can do some digging in the mean time.
Good luck.
