- Apr 28, 2003
I want to add wireless to my home network (which is wired). But it seems that APs are as expensive if not more expensive than a wireless router. Can I buy a wireless router (LINKSYS WRT54G in particular) and use it as an AP?
Procyon Lotor said:Thanks! I figured you could, but I didn't want to buy one and then find out that I couldn't.
four4875 said:is it marked something like internet or cable / dsl modem instead?
just curious, but why use the BEFSR41 to handle the load of processing and such and leave the power of the WRT54G being wasted? dont you have crashing problems with the BEFSR crashing when having high amounts of traffic? ive had nothing but trouble with the one at work. and be sure to update its firmware, theres some security holes on it.
edited typos...
