using extra case for setup....advice n33ded
Karbon
ok, i just got an aopen h700B, which is replacing my chieftec that the whole world has. i was originally just gonna put everything inside my aopen h700 and give away my case to a friend, but i think i should **** him and keep it for myself :D
i really wanted to be able to run two heatercores, so i think this will be pretty cool. how powerful of a pump would i need to do this- i was thinking either an iwaki md20rlzt or an eheim 1250 would be good. do u guys think this is a waste of money??? or do u think i might as well use the case :rolleyes:
advice would be mucho appreciated :p
I think you can fit 2 HC and a 1250 inside that case.
One on the front panel, and one using 2 5.25" bays.
The pump can be fitted inside a modded 3.5" bay or in the bottom of your case.
Suma.
I think its a waste of space to use a case that big to put water cooling in.
You can make it all fit into one case.
