- Jul 29, 2001
Hello. Today I tried something new: I put a little bit of tooth paste on my
heatsink and rubed it in with a plastic bag and then wiped the edges that
don't make contact with the CPU core (The toothpaste conducts elecrtricity!!!). Then u put a little bit of toothpaste
on the CPU as well and wipe it across the CPU core. Then just mount your
heatsink back on top of your CPU and you're done!
The temps in my case droped below the ambient temp thanks to the two
80mm fans that are blowing in the CPUs direction, but a ~10 C° drop in
temps garanteed.
The only thing you will propably have to replace the toothpaste once in 2-3 months. So if you're searching for not a long time solution this is perfect for ya.
temps garanteed.
