It is not galvanic reactions that I am concerned over, it is more or less straight corrosion, Brass is very susceptible to corrosion, almost as much so as 'soft' iron. So cupric sulfate is out, as is H2O2. And those are the most common algaecides on the market. So, yes - I am concerned about what I put into what may turn out to be a 3 to 4k NZD PC, BRFORE adding water cooling bits. I would not be surprised to see my next PC hit upwards of 6k to 7k NZD before it is finished. I would be a fool NOT to be concerned about what went into it.
Regarding PCIE gen 4, Intel would be wise at this point to start enabling more channels of PCIE on their newer CPUs, and while they are at it make them PCIe gen 4. Data centers thrive on fast storage, the faster the better, AI thrives on fast GPU's as well. And both need more PCIe lanes For this next build I will be using possibly 48 lanes, if I decide to go with two GPUs, and 32 lanes if not, and those lanes are just for the GPU(s) and SSDs. Intel just doesn't make such boards in the consumer space, let alone with PCIe gen 4. And they wonder why they are losing the data center race...
