- Nov 18, 2008
- Northwest Ohio
Code:
*********************** Log Started 2013-01-14T06:09:36Z ***********************
06:09:36:************************* Folding@home Client *************************
06:09:36: Website: http://folding.stanford.edu/
06:09:36: Copyright: (c) 2009-2012 Stanford University
06:09:36: Author: Joseph Coffland <[email protected]>
06:09:36: Args: --lifeline 3900 --command-port=36330
06:09:36: Config: C:/Users/BoutDrama'sBeast/AppData/Roaming/FAHClient/config.xml
06:09:36:******************************** Build ********************************
06:09:36: Version: 7.2.9
06:09:36: Date: Oct 3 2012
06:09:36: Time: 18:05:48
06:09:36: SVN Rev: 3578
06:09:36: Branch: fah/trunk/client
06:09:36: Compiler: Intel(R) C++ MSVC 1500 mode 1200
06:09:36: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
06:09:36: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
06:09:36: Platform: win32 XP
06:09:36: Bits: 32
06:09:36: Mode: Release
06:09:36:******************************* System ********************************
06:09:36: CPU: Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz
06:09:36: CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
06:09:36: CPUs: 8
06:09:36: Memory: 15.95GiB
06:09:36: Free Memory: 13.33GiB
06:09:36: Threads: WINDOWS_THREADS
06:09:36: On Battery: false
06:09:36: UTC offset: -8
06:09:36: PID: 5068
06:09:36: CWD: C:/Users/BoutDrama'sBeast/AppData/Roaming/FAHClient
06:09:36: OS: Windows 8 Pro with Media Center
06:09:36: OS Arch: AMD64
06:09:36: GPUs: 2
06:09:36: GPU 0: NVIDIA:3 GK104 [GeForce GTX 660 Ti]
06:09:36: GPU 1: NVIDIA:3 GK104 [GeForce GTX 660 Ti]
06:09:36: CUDA: 3.0
06:09:36: CUDA Driver: 5000
06:09:36:Win32 Service: false
06:09:36:***********************************************************************
06:09:36:<config>
06:09:36: <service-description v='Folding@home Client'/>
06:09:36: <service-restart v='true'/>
06:09:36: <service-restart-delay v='5000'/>
06:09:36:
06:09:36: <!-- Client Control -->
06:09:36: <cycle-rate v='4'/>
06:09:36: <cycles v='-1'/>
06:09:36: <data-directory v='.'/>
06:09:36: <disable-project-lookup v='false'/>
06:09:36: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
06:09:36: <exit-when-done v='false'/>
06:09:36: <threads v='4'/>
06:09:36:
06:09:36: <!-- Configuration -->
06:09:36: <config-rotate v='true'/>
06:09:36: <config-rotate-dir v='configs'/>
06:09:36: <config-rotate-max v='16'/>
06:09:36:
06:09:36: <!-- Debugging -->
06:09:36: <assignment-servers>
06:09:36: assign3.stanford.edu:8080 assign4.stanford.edu:80
06:09:36: </assignment-servers>
06:09:36: <capture-directory v='capture'/>
06:09:36: <capture-sockets v='false'/>
06:09:36: <debug-sockets v='false'/>
06:09:36: <exception-locations v='true'/>
06:09:36: <gpu-assignment-servers>
06:09:36: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
06:09:36: </gpu-assignment-servers>
06:09:36: <stack-traces v='false'/>
06:09:36:
06:09:36: <!-- Error Handling -->
06:09:36: <max-slot-errors v='5'/>
06:09:36: <max-unit-errors v='5'/>
06:09:36:
06:09:36: <!-- FahCore Control -->
06:09:36: <checkpoint v='15'/>
06:09:36: <core-dir v='cores'/>
06:09:36: <core-priority v='idle'/>
06:09:36: <cpu-affinity v='false'/>
06:09:36: <cpu-usage v='100'/>
06:09:36: <no-assembly v='false'/>
06:09:36:
06:09:36: <!-- Folding Slot Configuration -->
06:09:36: <cause-pref v='ANY'/>
06:09:36: <client-subtype v='STDCLI'/>
06:09:36: <client-type v='normal'/>
06:09:36: <cpu-species v='X86_PENTIUM_II'/>
06:09:36: <cpu-type v='AMD64'/>
06:09:36: <cpus v='-1'/>
06:09:36: <cuda-index v='0'/>
06:09:36: <gpu v='true'/>
06:09:36: <gpu-usage v='100'/>
06:09:36: <max-packet-size v='normal'/>
06:09:36: <opencl-index v='0'/>
06:09:36: <os-species v='UNKNOWN'/>
06:09:36: <os-type v='WIN32'/>
06:09:36: <project-key v='0'/>
06:09:36: <smp v='true'/>
06:09:36:
06:09:36: <!-- Logging -->
06:09:36: <log v='log.txt'/>
06:09:36: <log-color v='false'/>
06:09:36: <log-crlf v='true'/>
06:09:36: <log-date v='false'/>
06:09:36: <log-date-periodically v='21600'/>
06:09:36: <log-debug v='true'/>
06:09:36: <log-domain v='false'/>
06:09:36: <log-header v='true'/>
06:09:36: <log-level v='true'/>
06:09:36: <log-no-info-header v='true'/>
06:09:36: <log-redirect v='false'/>
06:09:36: <log-rotate v='true'/>
06:09:36: <log-rotate-dir v='logs'/>
06:09:36: <log-rotate-max v='16'/>
06:09:36: <log-short-level v='false'/>
06:09:36: <log-simple-domains v='true'/>
06:09:36: <log-thread-id v='false'/>
06:09:36: <log-thread-prefix v='true'/>
06:09:36: <log-time v='true'/>
06:09:36: <log-to-screen v='true'/>
06:09:36: <log-truncate v='false'/>
06:09:36: <verbosity v='9'/>
06:09:36:
06:09:36: <!-- Network -->
06:09:36: <proxy v=':8080'/>
06:09:36: <proxy-enable v='false'/>
06:09:36: <proxy-pass v=''/>
06:09:36: <proxy-user v=''/>
06:09:36:
06:09:36: <!-- Process Control -->
06:09:36: <child v='false'/>
06:09:36: <daemon v='false'/>
06:09:36: <pid v='false'/>
06:09:36: <pid-file v='Folding@home Client.pid'/>
06:09:36: <respawn v='false'/>
06:09:36: <service v='false'/>
06:09:36:
06:09:36: <!-- Remote Command Server -->
06:09:36: <command-address v='0.0.0.0'/>
06:09:36: <command-allow v='127.0.0.1'/>
06:09:36: <command-allow-no-pass v='127.0.0.1'/>
06:09:36: <command-deny v='0.0.0.0/0'/>
06:09:36: <command-deny-no-pass v='0.0.0.0/0'/>
06:09:36: <command-port v='36330'/>
06:09:36:
06:09:36: <!-- Slot Control -->
06:09:36: <max-shutdown-wait v='60'/>
06:09:36: <pause-on-battery v='false'/>
06:09:36: <pause-on-start v='false'/>
06:09:36:
06:09:36: <!-- User Information -->
06:09:36: <machine-id v='0'/>
06:09:36: <passkey v='********************************'/>
06:09:36: <team v='32'/>
06:09:36: <user v='GIXXERGUY6'/>
06:09:36:
06:09:36: <!-- Work Unit Control -->
06:09:36: <dump-after-deadline v='true'/>
06:09:36: <max-queue v='16'/>
06:09:36: <max-units v='0'/>
06:09:36: <next-unit-percentage v='99'/>
06:09:36:
06:09:36: <!-- Folding Slots -->
06:09:36: <slot id='0' type='GPU'/>
06:09:36: <slot id='1' type='GPU'/>
06:09:36: <slot id='2' type='SMP'/>
06:09:36:</config>
06:09:36:Trying to access database...
06:09:36:Successfully acquired database lock
06:09:36:Enabled folding slot 00: READY gpu:0:"GK104 [GeForce GTX 660 Ti]"
06:09:36:Enabled folding slot 01: READY gpu:1:"GK104 [GeForce GTX 660 Ti]"
06:09:36:Enabled folding slot 02: READY smp:8
06:09:36:Started thread 1 on PID 5068
06:09:36:Started thread 3 on PID 5068
06:09:36:Started thread 6 on PID 5068
06:09:36:WU02:FS02:Starting
06:09:36:Started thread 4 on PID 5068
06:09:36:Started thread 5 on PID 5068
06:09:36:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/BoutDrama'sBeast/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 702 -lifeline 5068 -checkpoint 15 -np 8
06:09:36:WU02:FS02:Started FahCore on PID 8892
06:09:36:Started thread 7 on PID 5068
06:09:36:WU02:FS02:Core PID:8820
06:09:36:WU02:FS02:FahCore 0xa4 started
06:09:36:WU03:FS01:Starting
06:09:36:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/BoutDrama'sBeast/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 03 -suffix 01 -version 702 -lifeline 5068 -checkpoint 15 -gpu 1
06:09:36:WU03:FS01:Started FahCore on PID 7992
06:09:36:Started thread 8 on PID 5068
06:09:36:WU03:FS01:Core PID:1860
06:09:37:WU03:FS01:FahCore 0x15 started
06:09:37:WU01:FS00:Starting
06:09:37:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/BoutDrama'sBeast/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 702 -lifeline 5068 -checkpoint 15 -gpu 0
06:09:37:WU01:FS00:Started FahCore on PID 3352
06:09:37:Started thread 9 on PID 5068
06:09:37:WU01:FS00:Core PID:5296
06:09:37:WU01:FS00:FahCore 0x15 started
06:09:37:WU02:FS02:0xa4:
06:09:37:WU02:FS02:0xa4:*------------------------------*
06:09:37:WU02:FS02:0xa4:Folding@Home Gromacs GB Core
06:09:37:WU02:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
06:09:37:WU02:FS02:0xa4:Preparing to commence simulation
06:09:37:WU02:FS02:0xa4:- Looking at optimizations...
06:09:37:WU02:FS02:0xa4:- Files status OK
06:09:37:WU02:FS02:0xa4:- Expanded 525260 -> 1190336 (decompressed 226.6 percent)
06:09:37:WU02:FS02:0xa4:Called DecompressByteArray: compressed_data_size=525260 data_size=1190336, decompressed_data_size=1190336 diff=0
06:09:37:WU02:FS02:0xa4:- Digital signature verified
06:09:37:WU02:FS02:0xa4:Project: 8028 (Run 2304, Clone 2, Gen 13)
06:09:37:WU02:FS02:0xa4:Assembly optimizations on if available.
06:09:37:WU02:FS02:0xa4:Entering M.D.
06:09:37:WU03:FS01:0x15:
06:09:37:WU03:FS01:0x15:*------------------------------*
06:09:37:WU03:FS01:0x15:Folding@Home GPU Core
06:09:37:WU03:FS01:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
06:09:37:WU03:FS01:0x15:Build host AmoebaRemote
06:09:37:WU03:FS01:0x15:Board Type NVIDIA/CUDA
06:09:37:WU03:FS01:0x15:Core 15
06:09:37:WU03:FS01:0x15:GPU device info vendor=0 device=0 name=NA match=0 deviceId=1
06:09:37:WU03:FS01:0x15:Window's signal control handler registered.
06:09:37:WU03:FS01:0x15:Preparing to commence simulation
06:09:37:WU03:FS01:0x15:- Looking at optimizations...
06:09:37:WU03:FS01:0x15:- Files status OK
06:09:37:WU03:FS01:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:09:37:WU03:FS01:0x15:- Expanded 126523 -> 507182 (decompressed 400.8 percent)
06:09:37:WU03:FS01:0x15:Called DecompressByteArray: compressed_data_size=126523 data_size=507182, decompressed_data_size=507182 diff=0
06:09:37:WU03:FS01:0x15:- Digital signature verified
06:09:37:WU01:FS00:0x15:
06:09:37:WU01:FS00:0x15:*------------------------------*
06:09:37:WU03:FS01:0x15:Project: 7624 (Run 16, Clone 0, Gen 174)
06:09:37:WU01:FS00:0x15:Folding@Home GPU Core
06:09:37:WU01:FS00:0x15:Version 2.25 (Wed May 9 17:03:01 EDT 2012)
06:09:37:WU03:FS01:0x15:Assembly optimizations on if available.
06:09:37:WU01:FS00:0x15:Build host AmoebaRemote
06:09:37:WU03:FS01:0x15:Entering M.D.
06:09:37:WU01:FS00:0x15:Board Type NVIDIA/CUDA
06:09:37:WU01:FS00:0x15:Core 15
06:09:37:WU01:FS00:0x15:Window's signal control handler registered.
06:09:37:WU01:FS00:0x15:Preparing to commence simulation
06:09:37:WU01:FS00:0x15:- Looking at optimizations...
06:09:37:WU01:FS00:0x15:- Files status OK
06:09:37:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
06:09:37:WU01:FS00:0x15:- Expanded 126085 -> 507182 (decompressed 402.2 percent)
06:09:37:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=126085 data_size=507182, decompressed_data_size=507182 diff=0
06:09:37:WU01:FS00:0x15:- Digital signature verified
06:09:37:WU01:FS00:0x15:Project: 7626 (Run 383, Clone 1, Gen 10)
06:09:37:WU01:FS00:0x15:Assembly optimizations on if available.
06:09:37:WU01:FS00:0x15:Entering M.D.
06:09:38:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
06:09:38:Started thread 10 on PID 5068
06:09:39:WU03:FS01:0x15:Tpr hash 03/wudata_01.tpr: 3564415828 2913191495 3046191093 2055691118 2112068286
06:09:39:WU03:FS01:0x15:GPU device id=1
06:09:39:WU03:FS01:0x15:Working on Protein
06:09:39:WU03:FS01:0x15:Client config unavailable.
06:09:39:WU01:FS00:0x15:Will resume from checkpoint file 01/wudata_01.ckp
06:09:39:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr: 2488239271 2350819058 198002580 1779942365 1017119481
06:09:39:WU01:FS00:0x15:GPU device id=0
06:09:39:WU01:FS00:0x15:Working on Protein
06:09:39:WU01:FS00:0x15:Client config unavailable.
06:09:39:WU03:FS01:0x15:Starting GUI Server
06:09:39:WU01:FS00:0x15:Starting GUI Server
06:09:43:WU02:FS02:0xa4:Using Gromacs checkpoints
06:09:43:WU02:FS02:0xa4:Mapping NT from 8 to 8
06:09:43:WU02:FS02:0xa4:Resuming from checkpoint
06:09:43:WU02:FS02:0xa4:Verified 02/wudata_01.log
06:09:43:WU02:FS02:0xa4:Verified 02/wudata_01.trr
06:09:43:WU02:FS02:0xa4:Verified 02/wudata_01.xtc
06:09:43:WU02:FS02:0xa4:Verified 02/wudata_01.edr
06:09:43:WU02:FS02:0xa4:Completed 14360 out of 500000 steps (2%)
06:10:16:WU02:FS02:0xa4:Completed 15000 out of 500000 steps (3%)
06:10:41:WU03:FS01:0x15:Setting checkpoint frequency: 400000
06:10:41:WU03:FS01:0x15:Completed 3 out of 40000000 steps (0%).
06:10:42:WU01:FS00:0x15:Resuming from checkpoint
06:10:42:WU01:FS00:0x15:fcCheckPointResume: retreived and current tpr file hash:
06:10:42:WU01:FS00:0x15: 0 2488239271 2488239271
06:10:42:WU01:FS00:0x15: 1 2350819058 2350819058
06:10:42:WU01:FS00:0x15: 2 198002580 198002580
06:10:42:WU01:FS00:0x15: 3 1779942365 1779942365
06:10:42:WU01:FS00:0x15: 4 1017119481 1017119481
06:10:42:WU01:FS00:0x15:fcCheckPointResume: file hashes same.
06:10:42:WU01:FS00:0x15:fcCheckPointResume: state restored.
06:10:42:WU01:FS00:0x15:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
06:10:42:WU01:FS00:0x15:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
06:10:42:WU01:FS00:0x15:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
06:10:42:WU01:FS00:0x15:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
06:10:42:WU01:FS00:0x15:fcCheckPointResume: state restored 2
06:10:42:WU01:FS00:0x15:Resumed from checkpoint
06:10:42:WU01:FS00:0x15:Setting checkpoint frequency: 400000
06:10:42:WU01:FS00:0x15:Completed 800001 out of 40000000 steps (2%).
06:11:40:Saving configuration to config.xml
06:11:40:<config>
06:11:40: <!-- FahCore Control -->
06:11:40: <core-priority v='low'/>
06:11:40:
06:11:40: <!-- Folding Slot Configuration -->
06:11:40: <gpu v='true'/>
06:11:40:
06:11:40: <!-- Logging -->
06:11:40: <verbosity v='5'/>
06:11:40:
06:11:40: <!-- Network -->
06:11:40: <proxy v=':8080'/>
06:11:40:
06:11:40: <!-- User Information -->
06:11:40: <passkey v='********************************'/>
06:11:40: <team v='32'/>
06:11:40: <user v='GIXXERGUY6'/>
06:11:40:
06:11:40: <!-- Folding Slots -->
06:11:40: <slot id='0' type='GPU'/>
06:11:40: <slot id='1' type='GPU'/>
06:11:40: <slot id='2' type='SMP'>
06:11:40: <cpus v='8'/>
06:11:40: </slot>
06:11:40:</config>
06:12:18:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
06:12:18:Started thread 11 on PID 5068
06:12:54:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
06:12:54:Started thread 12 on PID 5068
06:14:53:WU02:FS02:0xa4:Completed 20000 out of 500000 steps (4%)
06:16:17:WU01:FS00:0x15:Completed 1200000 out of 40000000 steps (3%).
06:16:41:WU03:FS01:0x15:Completed 400000 out of 40000000 steps (1%).
06:19:35:WU02:FS02:0xa4:Completed 25000 out of 500000 steps (5%)
06:21:55:WU01:FS00:0x15:Completed 1600000 out of 40000000 steps (4%).
06:22:48:WU03:FS01:0x15:Completed 800000 out of 40000000 steps (2%).
06:24:43:WU02:FS02:0xa4:Completed 30000 out of 500000 steps (6%)
smp is only pulling quad digits?????
Also how do I get hfm configured to see the v7 from a different computer on same network or even on a different network using hamachi
