- Oct 19, 2002
- St Petersburg, FL
I got my Nexus 201 from the first batch (I was on the waiting list) at SVC. Wish I'd waited to see how they were before buying, but thats a whole different post. . .
I've had mine running (after fixing the screw/pcb-short problem) just fine for the last few months with a Tornado (80mm) on channel 1 and 2 AddAs (80mms - stock Lian-Li fans) on channel 2. Today I finally got around to cutting a hole for the switch to my lights (2x 12" blue Cold Cathods - NOT HOOKED UP TO THE NEXUS) into one of the 3.5" bays and after putting everything back together, I fire it up, wait for the boot to finish and when I turned on the lights the Tornado died! They aren't even on the same lead from the PSU and no matter how I switched around the wires I couldnt' get the problem fixed. I tried monitoring voltages from my PSU in MBM and they seemed fine, but when I switched on the lights the MBM fan monitor showed the Tornado zipping up to 40K rpm, obviously a false reading. What could be causing this? How could the fan or Nexus be affected by the lights? I've read enough about the Sunbeam to know I'd really rather stick with my Nexus (I like the fact that you can't turn off a Tornado with it and the LEDs are just the right intensity for my room.) Tomorrow, I'm going to add some insulation to the bottom of the PCB just to be super-safe, but I don't get how a short would ONLY happen when the lights are switched on.
Any suggestions are welcome.
(sheesh - just re-read my post & it would seem I've had a few too many John Courages. . .sorry for any mis-spellings or nonsensicle stuffs.)
