I have several questions about fans and how they connect first of all. How does this work? Some have 3 wires, some have 3 pin, some are 4 pin. Do they go into the motherboard? Or the power supply? Can someone please explain this to me because there are different options when ordering fans and I am pretty lost in this department.
Another question is about cooling an overclocked XP 1600+. The case is going to be an Enlight 7237. Would it be possible to do the overclocking with the stock Enlight 300 watt power supply?
Next, how much is enough for cooling this thing? I was thinking Thermalright AX-7 with a 45 cfm Delta fan. I know this is good but should I get a Swiftech MCX370 instead for 15 dollars less? Now, for the case fans, what should I get for the 1 lower front intake and the rear exhaust? Do I even need a rear exhaust? There are a few Sunon's that I was looking at but how much cfm am I going to need (there are several different fan speeds that satisfy different needs).
Finally, I was thinking of a 120mm fan on the side of the case to blow on the cpu. Would this be needed or would this be overkill? How could I go about doing this.
Sorry for so many questions but I am kind of new at this stuff... Thanks a lot!
raley
raley
