VB refreshing a form/variable
Guid0
Kansas, USA
In a form i am using i am displaying system up time through GetTickCount, but how can i get it to refresh
IE:
time = GetTickCount.........
keep refreshing time untill app is closed........that way it can show current server uptime?
i am a newbie and I follow the K*I*S*S format
skip
OCForums Founder & Extraordinarily Elusive Adminis
Chicago, IL
Run it in a timer. You can easily set the refresh rate then.
G
Guid0
Kansas, USA
I tried that, but not sure how.........I tried doing a infinite loop with
time.refresh in it and before i did that i tried just doing a reguler for loop 100 times.........I think i got the concept of the timer wrong.
stymee
Troutman, NC
Then use the timer "event" to refresh whatever it is that you're trying to refresh.
The timer will then fire off whatever code you put in the event, at the interval you set.
Good luck!
