vCore adjustments on TUSL2-C
Toast
Greetings,
I am wondering what core voltage adjustments are available for Tualatin cpu's on the Asus TUSL2-C. If anyone has any insight in this regard, I would appreciate some feedback. Thanks,
Toast
With the new bioses I think voltages are adjustable to .300 or .325 above the default. I only have a coppermine, so I'm not 100% sure
it depends on the default voltage of your CPU. If your default is 1.475 then you can go up to 1.675. With the wire trick you can go up to 1.875
