- Aug 31, 2004
- Northwest Ohio
I probably wont be building a new system for at least a few more months, but I figured I might was well get back into the loop early.
Mostly I just wanted to know if you guys have any specific vendor preferences, or is it mostly just a variety depending on what you are needing to buy.
Also, Ive had this system water cooled for about 2 years, but Ive found that my tubing has been getting very clouded. I didnt know if this was just something us water coolers have to put up with, or if there is something I can do with my next project that might keep everything a little clearer over time. I think I used 10% antifreeze 90% distilled, but you know I might have made a mistake in measuring or calculating, I remember I was very anxious to get the system together that day.
One more
. Just wondering if there is any excellent cases out there set up for custom water cooling. I see that there are a few that are set up with kits inside of them, but that isnt something I'd be looking for.
Thanks for your time
One more
