- Nov 21, 2018
So i picked up 2 kits of this one sale pretty cheap. Would like faster but is what it is. And here are my results so far. Still messing with some timings and other stuff with the system.
All 4 sticks @ 3,364Mhz 16-17-17-39-60 1T 1.4v Stable as can be. Ryzen 7 1700X 4.163.9mhz 1.4v 101 bclk 41.25 multi soc @ 1.05v
Did a quick test @ 3,700Mhz with 22 sticks and it was stable. Cant remember what the timings were. I'll check that when i get some time and pull 2 sticks out.
Like i said i still gotta tweak everything i'll post some results but its anyone was looking at this ram and wanted some info on how it runs on Ryzen with 4 dimms here you go. Nothing to write home about but its not that bad. I got some other kits that are better but figured i would try this since since the price was right.
Few Notes
Box says works with RGB Fusion and MSI's Mystic light. However I cant get RGB fusion to work with them. Maybe because i have the icue software installed. Regardless i dont care.
icue software is great. Lots of options for the RGB. shows temps and all that.
RGB lighting on these is the best i have seen so far. Very nice. However the diffuses do a great job but you can make out the LED's. Looks great but look hard enough you see it. I'll pull them apart add a little scotch tape to the bottom of them to help fix that. Should be an easy but still looks great.
In terms of how strong my imc is in this cpu i have no idea. I know the cpu is good 4.28ghz +. But i dont know if the kit i tested that hit 3700 is normal for this combo or if that's an amazing kit. Only tested one kit have no idea what the other two sticks top out at because i just put those in without testing them.
System
Ryzen 7 1700X
Gigabyte Aorus Gaming 7 Bios F6e
2 X CMW16GXM2C3000C15 Hyinx die, Rev is 5. something i'll update when i take the 2 sticks out.
Custom Loop
Gigabyte Aorus GTX 1080ti
EVGA Super Nova 1000w
Not impressed with the ram speed. But not disappointed. Love the RGB and how clean it looks when running. I'll post up the final timings when i get them along with some info on running just 2 for those interested.
Few Notes
System
Ryzen 7 1700X
Custom Loop
AMD Ryzen 7 1700X @ 4163.91 MHz - CPU-Z VALIDATOR
[lawaw7] Validated Dump by DESKTOP-G5Q676S (2018-12-29 10:57:00) - MB: Gigabyte X470 AORUS GAMING 7 WIFI-CF - RAM: 32768 MB
valid.x86.fr
